Question about Emerson 32" Le320em3 720p 60hz Led Lcd Hdtv Tv
There is no power to my tv!!!!! I have an Emerson LE320EM3. It will not turn on. The red light will not come on either when it is turned off!!!!!
I have tried everything that I could think of to make it work. I really don't know what else that I can do to get it to work!!!!!
    New Friend:
    Problem Solver:
  • 5 Answers
Unfortunately these TV's are known for power supply issues. If you have power at the outlet and the cord is in good shape then it is most likely the power supply board. If you are competent on working on these at the component level, you can find replacement power supply boards for these on ebay for $20-$40 otherwise you will most likely find that it is not worth fixing, however you can try calling your local TV repair companies and see what they will charge you to repair or replace the power supply.
Posted on Nov 20, 2014
    Top Expert:
  • Emerson Master
  • 75,311 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
SOURCE: EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Posted on Apr 29, 2008
dsacco86
  • 1077 Answers
SOURCE: won't turn on
I want to save you time and money here.
A new TV just like the one you have at Walmart cost $189.
A TV repair shop will most likely charge you $100 just to look at it. And the part, Backlight Inverter/Power Supply Board ( I believe that is broken ) will cost $110 min ( That's a used part).
It would definitely cost more than $210 to repair the broken TV vs buying a replacement 19" TV at Walmart for $189.
Posted on May 26, 2009
dsacco86
  • 1077 Answers
SOURCE: I have an emerson flat screen that will not turn on ? The red stand by light comes on, but when you hit the power button the green light comes on then shuts off quickly and the TV will not come on?? A
Try leaving the TV unplugged for 30 mins so the TV can reset itself.
If that doesn't work, most cases with the Emerson TV, the Inverter Transformer goes bad on the backlight Inverter Board. It's what powers the screen for your TV. If it can't power up the screen, it automatically shuts off. Basically, they call this "Protection Mode" with this happens.
You can get a replacement backlight inverter board at this web site link:
http://www.shopjimmy.com/catalogsearch/result/index/?q=ewl3706+inverter&p=1&stock=all
Just make sure the board number matches your board.
If it fixes the problem and you decide to throw your old board in the trash, I would like to keep the damaged board if possible. I want to do some research on the board to find out what really causes the transformers to go bad. Here's my e-mail dsacco86@hotmail.com
Posted on Jun 03, 2009
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
No remote for Emerson # LE320EM3,how do you turn tv on.Has no power button
Look just inside the rear with a mirror. Sony hides them there as well.
EMERSON Replacement Remote Control for LE320EM3 ... - Amazon.ca
https://www.amazon.ca/Replacement-LE320EM3-LC501EM3.../dp/B00FKH6ME6
  1. Cached
EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3: Amazon.ca: Electronics.
EMERSON Replacement Remote Control for LE320EM3, LC501EM3 ...
https://www.amazon.com/Replacement-LE320EM3-LC501EM3.../B00FKH6ME6
  1. Cached
Find helpful customer reviews and review ratings for EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 ...
Amazon.com: Original New Remote Control / NH305UD: Home Audio ...
https://www.amazon.com/Original-New-Remote-Control-NH305UD/.../B015IFY96W
  1. Cached
Original Factory Remote - No need for programming it just works! Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, ...
Emerson LE320EM3 LE260EM3 Remote Control and Manual ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
  1. Cached
EMERSON LE320EM3 LE260EM3 REMOTE CONTROL AND MANUAL in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Accessories ...
Remote Control for Emerson TV ' eBay
www.ebay.com/bhp/remote-control-for-emerson-tv
  1. Cached
  2. Similar
Original New Remote Control / NH305UD by Emerson. Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, LE320EM3, ...
Emerson TV Remote Controls ' eBay
www.ebay.com > ... > Emerson TV Remote Controls
  1. Cached
www.newegg.com > ... > Audio / Video Accessories > Remote Support Inc
  1. Cached
  2. Similar
Buy EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 with fast shipping and top-rated customer service.
Redi-Remote EMERSON Replacement Remote Control for ... - Sears
www.sears.com/redi-remote-emerson...remote-control...le320em3/p-SPM925361391...
  1. Cached
Aug 23, 2015 - EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3. Emerson TV Remote Control. Emerson LE320EM3 Google Search
Nov 24, 2016 | Emerson Televison & Video
My Emerson LE320EM3 tv wont turn on, it has not flashing lights and only makes a high pitched frequency when plugged in.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 30, 2016 | Emerson 32" Le320em3 720p 60hz Led Lcd...
Wont power on
You put a fuse in the TV? Could you mean the remote control had no battery and you put one in? Maybe the remote is bad and you should try to turn on the set manually.
Here is the owners manual for your unit. If possible I would suggest taking it to a repair shop for quote on fixing it, but then you could probably buy a new better unit for what the cost may be to repair but you will have to decide that.
The link below will take you to download page at Emerson, when you type in your model number it must be in cap's. LE320EM3
DOWNLOAD
Mar 03, 2014 | Emerson 32 Inch LED HDTV
Emerson le320em3
TV model no. LE320EM3. I got up today to turn it on and it did not turn on. I unhooked it and plug it another outlet and it did not turn on.
Feb 14, 2013 | Emerson Televison & Video
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
My emerson tv standby light is on the power light flashes twice
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
I have a emerson 32 in.
fuse is blown cost about 100 to 150 to fix
Aug 07, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson 32" Le320em3 720p 60hz Led Lcd Hdtv Tv Logo
447 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
