Question about Garmin Rino 120 2-Way Radio
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
Switched channels and squelch codes
I have just the opposite problem. They can't hear my rino 120 until they talk to me first. Then it's like the radio recognized the other one. I can't talk more than 5 or 10 minutes without it going crazy on me again.
Posted on Nov 22, 2014
  • eradiostore
    eradiostore Nov 25, 2014
    Check the Motorola TalkAbout unit you are talking with to see if the qT filter is turned on. For smooth communication this quiet talk interrupt filter should be turned off when not used with other radios programmed identically. And one final thing to check would be any battery saver feature on either unit. This too can shut down communication if one radio goes to sleep.
  • Garmin Master
  • 1,654 Answers
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Posted on Nov 21, 2014
Testimonial: "I actually have had success for two or so hours talking between the Garmin 120 and the Motorola radios, but then, for no reason, the persons on the Motorola end can here me, but I cant hear them anymore, even after changing and trying different channels and codes...? its frustrating, to say the least! Any ideas on why I can no longer hear them? fresh batteries are in Garmin, and the Motorola walkie-talkies also!"
  • Michael McConeghy
    Michael McConeghy Nov 22, 2014
    Could use help if anyone else has had this issue!
  • eradiostore
    The problem is likely with the CODE used to block interference on the Garmin. Shut off the CODE (aka PL, private line, qT filter, interference eliminator code) on both units and see if you can then communicate. From your description it appears the Motorola unit has it turned off and the Garmin has it turned on.
What does Mon mean on a walkie talkie?
"Mon" is short for "Monitor" and is usually a feature that allows you to momentarily break the squelch (signal filter) and hear anything being transmitted on that frequency. That includes static if there's no transmissions. It allows you to listen for a weak signal that can't break the squelch threshold you have set. Some radios allow you to lock it open by pressing and holding the MON button for a few seconds. Turn the feature off my doing the same thing.
Jul 03, 2014 | Motorola Walkie Talkies 23-mile Range...
Radios do not communicate with each other
Are they both set on same channel ? Fully charged ? Volume high ? Or over-squelched ?.....
Apr 06, 2014 | Motorola Walkie Talkie 2-Way Radio
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Feb 28, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Problem unknown
Hello rixonsusu,
In situations where one radio cannot talk to another radio the problem is often caused by improper setting of the radio's Continuous Tone Coded Squelch System (CTCSS), which Motorola calls "Privacy Codes." (Other manufacturers might use different names, such as Kenwood calling this feature "Quiet Tones.")
When CTCSS is activated your radio's receiver will be muted unless the radio receives a signal from another radio using the required Privacy Code. This prevents you from having to listen to other user's conversations on what can be busy channels with a lot of activity.
In one of your radios has CTCSS enabled and the other does not, or if the other radio is set to the wrong CTCSS tone, the situation you describe will occur: one radio will be able to talk to the other, but that radio will not be able to talk back.
Make sure both of your radios are set to the same CTCSS privacy code or that CTCSS is turned off on both radios.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Pick up other walkie talkies
Should do. The available channels are defined by the regulator rather than by the manufacturer. Only thing to watch out for is similar looking devices designed to be sold into different markets (for instance, radios made to the European PMR446 standard work at a slightly lower frequency than those intended for sale in the US). A.
May 31, 2007 | Motorola Talkabout T5720 (7 Channels)...
Garmin Rino 120 2-Way Radio Logo
179 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
