Question about JVC Televison & Video
JVC TV turns on from standby the returns to standby after 30 -40-50 mins then back on after a few mins then standby after about 3 mins etc.
Time on gets shorter, time on standby longer until picture is on for seconds before returning to standby. Whwn on self induced standby will not respond to "on" signal from remote.
    Top Expert:
  • JVC Master
  • 74,136 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check for any loose solder terminals at its main power regulator section circuit. Re-solder all the suspected solder terminals; by applying a little more solder to each terminals. The fault is with any loose solder terminal/s at this circuit stage.
Posted on Nov 20, 2014
SOURCE: Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Posted on Aug 21, 2007
SOURCE: Westinghouse LVM-37w1 Goes immediately into standby mode
Power suplly. In my case I should have done research on a lot of things before purchase - westinghouse doe snot acknowled any power supplly uissue but they would say that, and this is a direct quote from them, "Westinghouse's failure rate is less than 2%, which is great by industry standards. Unfortunately, when you sell millions of televisions, 2% is still a lot of televisions. There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions."
In other words they calim there is nothing that is really their fault. However the first thing the repair guy said before he even looked at it was "Power supply". He opened it up and tested - power suplly. However to complicate matters more I made is huge mistake of buying into a scam offered by eCost via Service.net . A two year, 100%, in home service, warranty. Bottom line is since June 8 my Monitors has not worked and sine July 7 it has been sitting untouched, not here, but at a rprair facily over 50 miles away. As of yesterday August 7, I was told Westinghouse no longer makes or provides power supplies for this unit. On top of that the repair facility will not return it to me unless i pick it up why? Because it can't be fixed and because service.net will not pay them to return it to me.
So solution at thi point for anyone with power supply issues is to try and repiar it yourself. And then in the future never purchase anything from westinghouse again. (And if offered any sort of 100% all cost covere din home warrabnty from service.net run away screaming)
Posted on Aug 08, 2008
mistersony
  • 320 Answers
SOURCE: tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Posted on Nov 17, 2008
Shuttle83
  • 1139 Answers
SOURCE: Vizio SV470XVT1A makes screeching sound
This sounds as if it could be a ballast problem, or a switching power supply transformer problem. Both of these can produce this sound. I would suggest that you have a qualified TV technician repair this set due to the dangerous voltages and currents that could be present. In my experience with these TV I would have the technician pay special attention to the power supply board and the backlight/inverter section which includes the ballast used to fire the backlight.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 17, 2009
  • 32 Answers
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Posted on Jul 24, 2009
Hi when i connect my asus pc to my tv to show a powerpoint it works for about 10 mins then tv says no signal and counts down from 5 mins why is this what can i do?
check your tv settings for standby mode. It may be set for 10 minutes to turn off if there is no tv signal like a power saver feature. It may not recognize the computer as a signal input. If I put my tv on a channel with no signal, it will turn off automatically after a short time. The same happens if I have it in video mode for the vcr and if the vcr isn't playing, after a short time the tv will turn off.Good luck
Apr 19, 2015 | JVC AV-32260 32" TV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
After approximately 10 mins watching a dvd on JVC TH-1U system the screen turns to a yellow picture. Some times it will flicker between normal and yellow but then settles on yellow. Switch it off for 5...
This can be so many things, could be the color wheel, lamp, etc...depends on the type of tv.... If you got it from Best Buy and are in your 1 yr warranty or if you bought the service plan ( a must with any electronics) then give them a call and you will be all set.
Jun 07, 2008 | Televison & Video
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Televison & Video Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
