I live in Rio de Janeiro, Brasil and I need this vacuum cleaner. This is a product Singer,for customer assitance call 1 (800)845-5020.I have this adress: RYOBI MOTOR PRODUCTS CORP. 1424 Pearman Dairy Rd., Anderson. SC29625.
SOURCE: fan replacement on Generation 3 vacuum cleaner
Easily done!!! Here is a link to my online guide...
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Hope it helps!
Marci
SOURCE: fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
SOURCE: Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
SOURCE: Kirby Sentria vacuum -- can't figure out how to hook up main hose to vacuum floors
First you need to press the foot pedal for the height adjustment all the way down to lift the front of the vacuum off the floor. On the front top of the vacuum where the LED lights are is a cover. That section will lift up by lifting just below the LED's. Once it's lifted up there are some visual instructions, but here's what they are saying. The little circle on the front divided with the word KIRBY is the belt release. The section of the circle with the word on it will pull out. Like a wind-up flashlight it will turn from lining up with the green arrow counter clockwise 360 degrees and lining up with the red arrow. This takes a little pressure to turn it. Now just above this circle, under the LED bonnet, there is a lever that holds this whole front end on. It must be turned also counter clockwise to remove and front then slips off. The reverse would be used to put the beater roller portion back on. Also this would be the way to slip on the hose attachment to **** through it instead. I hope this is a little clearer.
