Question about Sharp Office Equipment & Supplies
I HAVE COPY MACHINE SHARP AR-5320E DISPLAY ERRO H2 AND NO FUNCTION PLEASE I WANT TO KNOW WHATS PROBLEM AND HOW CAN I REST CODE 14
ANY THING OK IN MACHINE ONLY THIS CODE APPEAR ON DISPLY BLANKING
  • 64 Answers
You have a heat issue. Go into service mode select code reset 14 and execute. Turn power off and on. Now if you don't know how to enter service mode. You need a qualified tech. You tap version twice that will give another screen select sim 14 and execute.
Posted on Nov 20, 2014
  • 61 Answers
SOURCE: My copier sharp AR-5320E is
H4 is a fuser problem, normally a reset will cure, to reset press these buttons
#, interupt, cancel (c), inturrupt. Display should say 'enter simulation'
enter 14, start, execute.
Switch off then on and it should work
Cheers
Posted on Jan 08, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
  • 175 Answers
SOURCE: H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Posted on Jun 23, 2009
  • 990 Answers
SOURCE: My sharp copier AR-5316 has the problem. Error
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
Posted on Oct 09, 2009
  • 9 Answers
SOURCE: sharp ar-m160 h2 error code
chack the fusing units the thermistor is open
&thermistor abnormality chack the harness and the
connector between the thermistor and the pwb
use simulation mode(# interaput c interaput )
preas the 14 toclear the self diagnostc dis play
Posted on Oct 30, 2009
I HAVE SHARP COPIER, THE MODEL NO IS AR-5320E. I AM HAVING THE PROBLEM OF H4 ERRO. PLEASE HELP ME
check heater section properly,(thermister,thermostat,heater lamp)go service mode and clear error code also
Sep 20, 2011 | Sharp AR-5320 Black and White Copier
The SHARP AR-5320e is blinking H and then 4 I changed the toner but it keeps doing the same thing.
H4 trouble can be cancelled. press #-interrupt-C-interrupt simultaneously. after that machine panel will black-out hence you can STILL input 14 (in numerical buttons). press start/copy button. Yala--ur machine will initialize again. hope it helps
Feb 12, 2011 | Sharp AR-5320 Black and White Copier
Power went out now my Sharp AR-M205 is coming up with code H2 how can i fixit
This code relates to temperature problem in the heating area or fuser unit . During copier warm up, a certain temperature must be sensed for it to work and it is not sensing that thus the code H2. Sort it out by keying the following codes in this sequence; Press #-*-C-* and display will go blank, enter key 14 on the panel display and press copy key. It will restart itself in a normal way. Good luck and happy new year.
Dec 09, 2010 | Sharp AR-M205 Copier
My sharp ar 5320e copier display me f2 code what shoud i do
Does it show if it is a f2-00 or any # after that? Sometimes you have to press the start key to display the rest of the nubers.
Oct 18, 2010 | Sharp AR-5320 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Model AR 5320E. Giving H2 error.
As we needed our copier very quick we had to call a qualified person to arrange the system.
Kind regards
Miriam4177
Jun 17, 2009 | Sharp AR-5320 Black and White Copier
My copier sharp AR-5320E is showing number 2 and letter H on the
H2 IS HEATER UNIT PROBLEM.IF SUB CODE IS 00 THEN IT SHOWS THAT FUSER THERMISTOR IS OPEN.USE SIMULTIONS 14 TO RESET IT.PROBLEM WILL BI SOLVED .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Jan 20, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar-5320e error code U2
please press these buttons in order #, interrupt,C , interrupt.
when display goes off enter 14 then start button it is ok
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
