Question about Fisher and Paykel Refrigerators
Decipher service codes for Fisher and Paykel refrigerator active smart RF170WDLX4 17.1 cubic feet bottom freezer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
You need a technican with a laptop to decipher the codes.
Posted on Jan 17, 2016
  • 15 Answers
SOURCE: fisher paykel e522bre active smart refrigerator
It could be one of 3 things. The circulator fan, the defrost timer or the defrost thermostat. Your schematic should show where these parts are on the unit
Posted on Mar 22, 2010
sonicboomele
  • 1557 Answers
you need to have the defrost element replaced !!
Posted on May 15, 2010
Daniel S
  • 4323 Answers
SOURCE: My Fisher and Paykel Active
Hi
If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 14, 2011
Ironfist109
  • 3018 Answers
SOURCE: I have 2005 model of
  • Sure it can be due to lack of gas. You can't check the pressure because one has to be certified to fool with the gases. But we can narrow it down to weather or not it might be the gases or not. The refrigerant system is sealed and will never leak out if there is never a leak.It will in theory always blow cold air. When you had it gassed did they repair a leak? If not the gases could have seeped out again. Just like in a car, same set up. You had to have it gassed for a reason and if that reason was not repaired it could very well be the problem.
  • Are the fans in the refrigerator running at all? In the freezer part? If the fans don't circulate then the cold air will not either. Unlikely that both will go at the same time but not impossible.
  • Is your compressor running at all? On the compressor you should have a relay. If you pull it out and shake it does it rattle like it has rocks in it? This can be your problem.
  • Also look around the coils around the compressor. Where the gasses travel. You will want to look for rusted or "greening" of the copper pipes. This can be a good indicator of a possible spot that is leaking. To test the actual gasses and the pressure you need gauges and the know how to use them.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 31, 2011
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Smart reach refrigerator w/
WHY? You have a bet with someone?
Posted on Aug 24, 2011
What does fisher paykel fault code f0 mean?
Faulty freezer temperature sensor - this would be for an older model fridge
Feb 23, 2016 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
What is fault code 2 for Fisher & Paykel refrigerator model E522B?
The resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
Primary Action
- Check sensor connection at controller.
Secondary Action
- Replace sensor.
Jul 11, 2011 | Fisher and Paykel Active Smart E522B...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
66 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
