Question about Dell Computers & Internet
My husband has a 14 year old Dell computer. He purchased an Acomdata external drive around 2007. He is desirous of transferring the data from the internal drive on his old computer to his Acomdata e
My husband has a 14 year old Dell computer. He purchased an Acomdata external drive around 2007. He is desirous of transferring the data from the internal drive on his old computer to his Acomdata external drive and then transfer it to a new computer he has just purchased. Is this possible?
    New Friend:
  • 18 Answers
He should be able to do that , Doris. Although it may be a slow process. His external hard drive is equipped with USB version 2.0. If his old computer is version 1.0 it may take a while. The good news is that the two versions are compatible. you can read more about USB here. P.S. I've done this many times with my external drive.
USB Wikipedia the free encyclopedia
Posted on Nov 20, 2014
suisboy
  • 175 Answers
SOURCE: Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Posted on Jan 06, 2008
Benimur
  • 6966 Answers
SOURCE: transferring an internal hard drive to another computer
There are several ways but the easiest would be to use an external USB interface such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the IDE connections to your old hard drive as well as a USB cord to your new PC's USB port. This is of course assuming that all you would want is access to the files/data in the old hard drive.
If your plan is to use the old hard drive as the master (meaning you want to boot from it and use your old OS with its settings on the new PC), chances are you would need to reinstall/repair the old OS since it would not run in the new PC.
If you want to install the old HD as a permanent device inside the new PC, you would need an IDE connector and install the old HD as a secondary master/slave.
If you just need to copy/move files from the old HD to the new PC, the initial method would be your best bet. The interface can be borrowed for a one time use.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
  • 152 Answers
SOURCE: Installing external hard drive internally
i really doubt that you can use it as an internal drive..
i would guess that changing the battery source would be your best bet.. so try to send it for repairment..
the other thing that could have happened is that you lost your entire information from some sort of burnment... that also can happen on internal disk when a power failure comes..
so if you have really really important information and need to take it back, you could try changing the plates to another one of the same model and rescue the info from there..
and yes.. it is insane and extremely hard to do.. but there is a group of people on the internet that specialice on getting information from disk and stuff..... they once got some info from a disquette that got cutted with a pair of sisccors, what they did was put all the pieces of the disk back together with scotch tape and put everything back into another flopply disk case..and it worked... so my theory of changing the plates is quite posible, but somewhat unnesesary for the huge ammount of work...
Posted on Mar 26, 2008
pagebor
  • 2785 Answers
SOURCE: can i transfer data from a damaged drive to a new one?
data is not loss but you have to give the disk to data back up professional
Posted on May 15, 2008
Benimur
  • 6966 Answers
SOURCE: Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 01, 2008
We have a Windows XP system on a 14 year old Dell computer.. We are desirous of transferring data from that system to a new computor. My husband purchased an Acomdata Hi-speed 2.0 external hard drive...
If both your Dell and the hard drive have USB ports you may be able to download directly. Other wise you may purchase an external drive and load the data to that. The external drive almost certainly will connect by USB.
Nov 19, 2014 | Dell Computers & Internet
Acomdata external hard drive not opening MBP
Acomdata Drive Not Recognized: I ran into the same issue. Actually the issue was with using an incorrect power adapter. It should be with power ratings of: Input 50-60 Hz 1.2A & Output 5V - 2A, 12V - 1.2A
Jun 22, 2012 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
I am using a dell laptop and want to know how to transfer files from my laptop to my computer but the cd doesnt really show you how.
Data can be transferred from one computer to another using a Pen-Drive or External Hard Disk (depending upon the size of data). All you have to do is copy and paste the selected/ desired data and No additional software is needed.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 15, 2011 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Unable to transfer files from an acomdata external hard drive.
Borrow a friends "hard drive docking station" and remove the hard drive from the other external drive and place in the docking station and see if you can read the drives contents. The docking stations can be purchased at Best Buy or Office Depot if you want your own. Your external drive could have a faulty power supply or you really could have a hard drive that has developed bad sectors and that is a disaster for your data. When a drive starts acting up, you really need to act and transfer important files to a new drive or burn the data to DVD's.
Apr 14, 2017 | Computers & Internet
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
T your concern:
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
External hard drive will not turn on
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
Keep me posted.
Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Computers & Internet Logo
256 people viewed this question
Alun Cox
