Question about LG Televison & Video
How do i reset the input options for my LG 50GA6400 Television? It won't allow me to configure HDMI connection
I inaccurately configured the wrong connection, so it's trying to use the internal coax connection....need to switch it back to configure HDMI option, but all of those are greyed out.
    Top Expert:
  • LG Master
  • 75,311 Answers
Try a reset to this TV; and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Posted on Nov 20, 2014
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Posted on Feb 21, 2009
jomabug76
  • 1148 Answers
SOURCE: No sound with HDMI connection.
COULD BE A BAD HDMI,,CHECK TO SEE IF ITS TURNED ON ON THE CABLE BOX
Posted on May 15, 2009
Turk_97
  • 131 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
SOURCE: Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Posted on Dec 17, 2010
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
Reset lg 50ga6400 input options
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 19, 2014 | LG Televison & Video
Baird tv
Two things you can try:
Check the remote control and press the button for Digital input. Someone may have set the tv to expect an analogue signal from the aerial while you were pouring your wine. Because the analogue tv signal has been switched off the tv won\'t be receiving anything off-air. It will need setting back to digital to receive Freeview.
OR
The television set may be dropping itself into "AV" mode and is expecting an input through a SCART or HDMI socket. Sometimes an external device (video or DVD player) will hijack the television if the set-up hs been configured for this. Try unplugging all external devices (Sky box, DVD, VCR, games console or whatever you have plugged in). Make sure that the telly is configured to digital input and tuned to BBC1. Then see if the it will show the programme.
If the television is actually broke then you should return it if it\'s still under guarantee.
Jul 15, 2013 | Televison & Video
My lg flatron n2294a - PM displays an "out of range" message and won't wirk with my ps3 when using the hdmi or AV option. Whats wrong?
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Apr 01, 2013 | Computers & Internet
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
How do i connect my lg video to my lg tv
Hi! If your TV does have HDMI (as your DVD) then this will be without doubt the best way. You will be getting great image quality and there is zero configuration needed. Just connect them by HDMI and select HDMI INPUT on your tv
Also, by using HDMI, and since both devices are LG, you will realize you can use one special button you can locate on both your remotes, it's called simplelink. Pressing this button will allow you to use some special features not available with another connection.
If you can go this way you will realize configuration is pretty straightforward and, in no time, you will have your whole system working ;)
Miquel.
Mar 05, 2011 | LG DBRH197H DVD Player/HDD Recorder
How do you connect the speakers on to your flat tv. I read it on the manual that u have to use HDMI, but i did. It still won't work.
This model has speakers. If you are trying to connect external speakers i.e. a home theater system, receiver or a sound bar you have a couple options.
This television only has hdmi inputs so you cannot connect the external speakers with hdmi cables. The television would have to have and hdmi output.
Now in order to use hdmi you would have to connect all your devices to the home theater and then go hdmi out from the home theater to one of the two hdmi inputs on this television. Then you would leave the television on that hdmi input at all times and switch devices with the home theater remote.
All the devices would be connected from their respective outputs to a respective input on the home theater.
Another option is to connect a fiber optic cable from the television to the home theater.
Another option would allow for stereo sound but not the higher quality surround sound. You can connect from your televisions red and white RCA outputs to the RCA input on the home theater.
Dec 30, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
you can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Jun 30, 2009 | Denon AVR-1907 Receiver
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
Televison & Video Logo
75 people viewed this question
Computer Repairing
Computer Repairing
