Question about Dacor Kitchen Ranges
I would like a higher BTU gas range and is shopping around for new range.
I tested by boiling 2Q of water bringing temp from 66 to 166 and this took 8 minutes. I estimated that the BTU is 8000 and just wanted to confirm if this is correct. I would like a higher BTU gas range and is shopping around for new range.
    Champion:
  • 254 Answers
Most range manufacturers give you the but rating for there burners. I have an electric range that has a "fast boil" burner. It can bring a gallon of water to a full boil in about 10-12 minutes. I also have a commercial gas (propane) range. Its burners are rated around 33,000 btu
Posted on Nov 22, 2014
  • 112 Answers
SOURCE: Vulcan Range that wasn't heating.
The half inch tubing should be adequate under most circumstances. However, you may run into volume issues while using the oven and a few burners at the same time. If it bothers you, replace it. The door should be flush (or close to it) on the sides and the top. If you have an air gap, check the hinges.
Posted on Nov 10, 2008
SOURCE: Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Posted on Dec 09, 2008
  • 22 Answers
SOURCE: so slow heating up/boiling water
Find you a GASMAN to resize your orifices. He will have special drill bits to do so. If I were there I could do it for you.
Posted on Dec 25, 2009
SOURCE: Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Posted on Jul 08, 2010
richroth
  • 9472 Answers
SOURCE: I have a Kenmore Gas range. The major stove top
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Posted on Jan 16, 2011
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Have a 2001 ram 2500 v8. Can't get heat in cab above 95. Changed leaking radiator over summer. Since than have changed thermostat, flushed heater core and changed hoses. Engine temp won't go above175...
did you replace the thermostat with a brand new unit . If so pull it out and check it in water with a thermometer . Suspend the unit in water to the mounting plate and bring the water to the boil . The flap should start opening at the lower reading set on the body and be fully opened at the higher reading . If the flap is partially open at cold then replace it as it is unserviceable to start with. Thermostats can be bought with at least 2 temperature temp ranges depending on the area of operation so get a higher opening reading one for your purposes.
Feb 09, 2014 | Cars & Trucks
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Temperature fluctuates while flow remains constant.(within the pump cut in/out settings) Max temp obtainable 43c
This sounds like a common problem with tankless type water heaters. The modulating burner has a set Btu range it can operate within, a maximum and minimum. With very low flow rates and very low temperature rises, the burner has trouble maintaining a steady output temperature because the btu load drops below the heater's minimum input. Typically the machine will overheat the water beyond it's setpoint, the burner will cut out, and then re-ignite once the output temperature has dropped low enough.
The solution to stopping this behavior is to simply increase the water flow through the device (i.e. higher flowing fixture or larger pump). This type of problem is exaserbated with recirculation systems that bring a very high water temperature to the unit.
Higher end tankless brands have a lower minimum input btu and thus fewer problems with this.
Aug 17, 2009 | Bosch Water Heaters
So slow heating up/boiling water
Apr 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Kitchen Ranges Logo
79 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
