Question about Asko Dishwashers
Water cuming back up through into the sink then going down
Carb soda &vinager taking hose off cleaning waste area cleaning filters now water sitting in well of filters is it normal ,can I now replace filters &screw them down over well thank you so much
    Sergeant:
  • 244 Answers
Your description is a little unclear but if water is coming up out of the disposal when the dishwasher drains then it was likely improperly installed. The dishwasher's drain hose should be connected to an air gap device that drains the water into the sink above the disposal, not connected directly to the disposal's side port unless the dishwasher has a built-in check valve to prevent the contents of the disposal from siphoning back into the dishwasher.
Posted on Nov 20, 2014
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
SOURCE: Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
Posted on May 05, 2009
  • 132 Answers
SOURCE: MIELE NOVOTRONIC W939
IF YOUR PROBLEM STILL THERE DONOT TRY TO PLAY WITH INLET BECAUSE IT HAS ABIG WATER PRESSUR CAN HIRT
THANKS
Posted on Jul 12, 2009
SOURCE: overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
Posted on Jan 13, 2010
Remove hard water and soap **** from marble
Make a paste of 1/3 baking soda to 2/3 water and let this sit on the marble for about 24 hours. Test a small area if it's not clean spray vinager right over top of the paste. This will start a chemical reaction that will foam up and take those hard water stains right off.
Apr 07, 2014 | Crafts & Hobbies
Water is not getting drained from the botom of the machine
There are several possibilities as to why water isn't draining from your washer:
1. Blocked drain filter
The filter is usually at the bottom of the wash compartment. You didn't state which model of dishwasher you have, so please refer to your user manual for instructions for cleaning your filter. If you don't have a manual, please post back here with your dishwasher brand and model number for information on cleaning your filter and where to download a manual if one is available.
2. Blocked/kinked waste hose
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages both in the end of the hose and at the sink attachment. If there is a lot of dirt in the hose, it may be blocked somewhere further back.
3. Blocked waste disposal / sink trap / waste outflow
Make sure your sink is draining efficiently. Clean as necessary
4. Faulty waste pump
If all of the above check out, you may have a faulty pump. Please post back for further advice regarding this after completing the above checks.
Regards,
BElectric
Nov 20, 2010 | Dishwashers
Water is clogged in the bottm of the unit. how do I clear the drain?
The drain filter is clearly visible at the bottom of the wash compartment but there are several possibilities as to why there is still water in the bottom of your washer:
At the bottom of the wash compartment, there is a fine mesh grille and a plastic cylinder which protrudes from it. Grip the plastic cylinder, twist anti-clockwise and pull it upwards. To clean it, remove any debris from the cylinder, rinse then replace in reverse order of the above.
Check the waste outflow hose at the back of the washer for any kinks or other damage. Also remove the hose where it attaches to your sink (or waste outlet) and check for any blockages.
Regards,
BElectric
Nov 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The waste water backs up into the dishwasher when sink is plugged
Dishwasher manufacturers recommend a syphon break be fitted - but usually there is not a problem if your sink has an overflow pipe incorporated.
You have a partially blocked drain - causing wastewater to flow into the dishwasher instead.
Use 1/2 a cup of caustic soda or proprietary drain cleaner down the sink drain. Add about a pint of water, and leave overnight.
Next morning pour a full boiling kettle down the drain which should move things on and clear the drain.
You may have to repeat this process once, but is preferable to taking your pipework apart - which is next if this does not clear it.
Sep 14, 2009 | Dishwashers
Sitting water in washing machine (not immediately after use)
if it is dirty water then it sounds like it's coming from the sink if washing machine waste is plumbed to the sink make sure washing machine waste pipe is higher than the sink waste outlet if it is clean water then a new water valve is what's needed
Jul 15, 2009 | Washing Machines
My 1991 yamaha fzr 600 has been sitting for three years same gas and oil and filters. it starts with a full choke but when you give it any thorottle it bogs out and dies
Any water in the gas? Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? ( not all bikes have a water trap bowl ). Drain all the old gas from the tank. Install an in-line fuel filter. You will need to clean the built up varnish from the evaporated gas out of the carbs.
FOR EACH carb > Remove the float bowl and clean the entire
carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Balance and sync the carbs.
I strongly suggest you to let the shop take care of the carbs. Cleaning can be a nightmare times four and doing the balancing and sync of the carbs sounds easier than it is. If you do the carb work then be sure you have a fire extinguisher at hand. I am serious about that.
Please rate this solution. Thanks!
Mar 29, 2009 | 1991 Yamaha FZR 600
There is gum stuck somewhere in my dishwasher drain line. The water won't go down. I took the inside apart and can see the hole where the drain water goes. I disconnected the drain hose under the sink. I...
ther e is noo easy fix, short of replacing the drain line( if indeed thats where the clog is)although you checked the hose from the under the sink, did you check with in the hole where the sink conection is made??and try disconnecting the drain hose from the d/w itself and blow toward sink..
Jan 25, 2009 | Dishwashers
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Vacuum smells
My wife happens to have a rainbow that I picked up at an auction for $2.00.
When it begins to smell, we use a quarter cup of vinagar in with the water and use as usual.
You may not apprectiate the smell of vinagar, believe me, it works.
It may take a couple of vacuum sessions and changing of the vinager water each time, but one good thing about vinagar, it is an old time disinfectant.
Feb 07, 2008 | Vacuums
Dishwashers Logo
65 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
