My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
Asked the neighbor to use the key to unlock his car AFTER I checked the function of the bell (was ok) and... after the car was unlocked... the doorbell didn't react to the push button! My guess: they both work on a similar frequency and the bell "got confused". I have to switch the bell off.... wait 10 sec... power up and - works.
  • Office Equip... Master
  • 9,639 Answers
Look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Posted on Nov 20, 2014
SOURCE: Unable to lock/unlock doors with key or remote
Lockng seems to have self cured itself remote button has to be held for 2 seconds each time to operate the lock/unlock system.
Broadband system up and running with no ill effect.
Posted on Jun 05, 2008
SOURCE: 2005 Nissan Maxima, Power Locks Wont Work
All four door lock actuators were bad, fussed enough with dealer , they are fixing for free, save me $1600!
Posted on Nov 04, 2008
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Posted on Jul 10, 2009
SOURCE: 99 4-runner limited-power door locks dont lock, but will unlock
I have found a ridiculous solution for this door lock issue. As many people have mentioned, it does involve the control panel under the driver side dash. I noticed that if I pushed the control panel/fusebox in while working the key fob and/or door lock switch, IT WORKED! So, my silly solution was to insert a t-ball (regulation size) between the fusebox/control panel and the paneling closest to the driver on the top side of the fusebox. IT WORKS!!
Glad I didn't spend $500 for Toyota dealer to fix.
Hope my son doesn't miss his t-ball!!
Posted on Jul 15, 2009
  • 105 Answers
SOURCE: My 2002 Honda Cr-V's keyless remote has stopped working.
drivers central door locking module is kaput and needs flinging as far as you can then replace it with a new one or a salvaged one
Posted on Dec 28, 2009
Garage door opens by itself mostly at night.
Sounds like someone nearby has the same opener. Change your code.
Sep 01, 2015 | Building Materials
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
Nov 19, 2014 | Cars & Trucks
My GE doorbell ringes when neighbor pushes his doorbell. Help
You have to change the frequency so they won't do that.
Aug 29, 2013 | Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Everytime somebody rings my neighbors doorbell, our doorbell goes off as well. can i change something to make that not happeb anymore?
It appears that you and your neighbor's wireless door bell are on the same radio frequency. You or your neighbor will need to change their base station (were the sound come out of) unit. If you or your neighbor still have their Owner's Manual you can find out how to do it in the Trouble Shooting Section. If that's not available, remove the cover, if necessary and you will find a small panel board with a series of movable slid switches (they are very small) . Moving those to a different position will change the frequency. The inside of the back cover should have instructions on how to reprogram it. DESA International bankrupted over a year ago, but some manuals in a pdf format are still available on line. Try http://www.desatech.com/ as there may be an Owners Manual that's still available. Different divisions of DESA International were sold off to other companies during the bankruptcy, so you may be led to another site. Good luck.
Jan 15, 2011 | Desa International White Wireless Plug In...
JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
May 14, 2010 | Desa International White Wireless Plug In...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
My pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Dec 29, 2008 | Desa International White Wireless Plug In...
Doorbell frequencies.
Check the reciever (ringer) as well, it will have to be set to match what you do to the transmitter (the doorbell button)
Jan 12, 2008 | Computers & Internet
606 people viewed this question
jasbo
jasbo
