Question about Iview 3500STBII Multi-Function Digital Converter Box
How to fix and set password from iview 3500stb2?
I forgot my input old password at iview 3500stb11 multi-function digital converter box .
How could I set my I view universal remote to my tv
search the code of the tv then encode it to you remote..every tv has a specific code
Feb 16, 2015 | Iview 3500STBII Multi-Function Digital...
Can you connect a hd converter to a Toshiba cx 32 g60 tv
there isn't much point in connecting an hd converter the toshiba cx32g60. the tv can only support an sd signal (composite video or ntsc analog). however, many hd set-top boxes (dvd players, cable and satellite) have composite outputs. these can be connected to your tv. blu-ray videos can't be watched with this tv. (the hdcp (high definition copy protection) can't be sent through most converters.)
if you want to watch ota programming , the cheapest option would be to find an sd digital-to-analog converter. these were the ones sold when most stations switched to digital tuners. some are being sold off as people replace their old analog sets. there are some hd tuner boxes, like this one: http://www.solidsignal.com/pview.asp?mc=03&p=3500stb&d=iview-hd-dvr-receiverconverter-box-for-tv-antenna-qam-%283500stb%29&c=digital%20converter%20boxes&sku= , that have composite video output which will connect to the cx32g60.
i hope this helps.
cindy wells
(if you tried an hdmi to component video converter followed by a component to composite video converter, the signal may degrade excessively.)
Jan 22, 2015 | Toshiba Televison & Video
MY BOX KEEPS SAYING BOOT DID i CONNECT SOMETHING WRONG
Antenna cable would go into ANT in
What cable did you use to connect box to tv.
I don't have the user manual so I am guessing that ANT out is for analogue channels 3 and 4 to go through to the tv. think
I suspect the coaxial out would go out to a video in type connection on the television.
If the Television has HDMI inputs I
you should go out and buy a HDMI cable and use HDMI out on the box.
Does the remote control for the box have a plastic strip in the battery compartment that stops the batteries. Or are batteries in the battery compartment.?
Jan 15, 2015 | Iview 3500STBII Multi-Function Digital...
What type of coaxial wire is supposed to come with the 3500STBII multimedia converter box? It didn't come with mine and I am having trouble making it work.
Input coaxial signal needs to be digital only There is a blog on AVS with most info such as firmware updating and what works the best. I have one myself and works well for me. Note: input needs to be digital from outside antenna or receiver giving digital output only.
May 26, 2014 | Iview 3500STBII Multi-Function Digital...
What kind of coaxial wire is supposed to come with the box?
Info on the DVR which I use myself can be found at iView 3500STB Tuner DVR Owners Thread Remember the input needs to be digital not analog. You can not take a signal from a cable box to the input side of the 3500STB as is a anolog signal
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
Iview 3500STBII Multi-Function Digital Converter Box Logo
64 people viewed this question
Top Iview Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Iview Office Equipment and Supply Expert? Answer questions, earn points and help others
