Question about Throttle Position Sensor Ford Bronco 96 95 94 93 92 91 90 89 Ss10426
93 ford Bronco died while driving and now won't start
Brand new battery acts like no power at all
    Champion:
  • 254 Answers
Alternator is bad.
To check:
1. Disconnect the new battery from Bronco.
2. Use another battery in place of your new battery (one that's inside).
3. If Bronco buck, then the Alternator is defective & not charging the new battery.
Check those two cables to Alternator.
Check with a DVM.
4. Or take out the new battery and have Advance Auto Part or AutoZone check for CCA rating.
atdlee@netzero.com
Posted on Nov 20, 2014
Bronco II won't start
86 ford bronco 2 won't start changed coil wire acts like it wants to start not getting spark
Nov 10, 2012 | 1988 Ford Bronco II
Won't start properly
could be the starter relay .
Nov 02, 2012 | 2000 Ford Taurus
My 1987 Ford Bronco II won't start
First you always test things & never replace anything
When you understand how things work & how to test
them,then they have to fail a test in order to need replacing
I would think Fuel Pump--if it quite while driving
Put a gauge on the motor if you have a shrader
valve to do so
Seldom do you need to replace a dist
The parts inside can be diagnosed & replaced
if you can source them
Things like plugs,wires & such you leave until you
know if you have fuel pressure,spark & so on.
Once a vehicle gets to 20 years of age you start
checking for wire corrosion such as around fusible links
Never forget the battery & it's cables & the internal
corrosion possible there
Worn ignition switch a possible
You say won't start,so I assume the engine
does turn over?
Oct 01, 2012 | 1987 Ford Bronco II
2001 mustang has new battery, won't start unless it's jumped, then dies after trying to drive a few yards
You have a defective alternator most likely, have it tested by any Autozone it is free.
Jul 10, 2012 | Ford Cars & Trucks
I have a 1989 ford bronco,I replaced the fuelpump and it won't start,checked the relays ,only comes on if I run it direct,but it constantly runs,how ever it still won't start.If I put gas down the...
may be a fuse or coil check for spark had simaler prob with a jeep ended up being a fuse for somthing completly differend but they run in same sercut
Mar 02, 2012 | 1989 Ford Bronco
New battery drains in two days on 93 chevy s10 blazer
Is the battery goind dead while the vehicle is sitting and just won't start? Or is it dying while you are driving it?
Nov 25, 2011 | 1993 Chevrolet S-10 Blazer
Engine turns over but does not start .how to change the fuel pump?
does it start if you spray starting fluid down the intake?
Nov 08, 2009 | 1993 Ford Bronco
1983 ford bronco 302 engine wont stay running after jumped
keep in mind, your engine use both source of power to run, one from the battery and one form alternator. If the alternator is good, your engine should stay running regardless if the battery is good or bad, the alternator should keep the engine running. It sound like to me the alternator is faulty not charging your battery or keeping your engine running, even though the alternator is brand new does not mean is good. My guess I would take the alternator back and get another one. the reason why your car ran for 25 min and die it has no source of power to keep the sparks going although the alternator should keep the engine running and at the same time charging the battery but is not.
Jul 12, 2009 | 1995 Chevrolet Caprice
Throttle Position Sensor Ford Bronco 96 95 94 93 92 91 90 89 Ss10426 Logo
110 people viewed this question
Top Delphi Vehicle Parts & Accessories Experts
Doberman
Roni Bartlett
Roni Bartlett
Level 1 Expert
Are you a Delphi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
