Question about Inverter KEB COMBIVERT F5
After a service to the motor bearing that also touch the encoder. when I switch on the power the motor is already running.at first it should be on stop position
How to reset this unit?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
The inverter will only do what it is being signaled to do. Check the control signals to the inverter and make sure that they are correct.
Since there is an encoder on the system, I will assume that this is a closed loop system. Try to home the system.
Posted on Nov 25, 2014
I have a 2000 4x4 suburban it says service 4x4. I already replaced the switch and the transfer case acuator with the encoder. It still says service 4x4 and it feels like it is in 4x4 when i give a slow...
When you remove the encoder motor, you should be able to manually shift the transfer case. If all is working manually and it "comes out" of 4wd, you may need to have the TCCM reprogrammed.
Oct 26, 2013 | 1999 Chevrolet Silverado 1500
99 Chevy Silverado 4x4 not working No light on 4x4 Selector Panel
Your brake an CV joint issue can't an won't cause your 4X4 problem . The 4x4 system has a control module which supply's B+ voltage to the switch . Checking for codes in the 4X4 control module should have been the first step . Your best bet , take it to a qualified repair shop . You don't have the knowledge or test equipment to fix this.
SERVICE indicator (4WD/AWD) Lamp
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via CKT 1567.
Transfer Case Shift Control Module
The transfer case shift control module uses the VIN information for calculations that are required for the different calibrations used based on axle ratio, transmission, tire size, and engine. The system does not know which calibration to use without this information.
The direct battery supply line (CKT 1640) provides the power to the module and motor circuitry.
Transfer Case Encoder Motor
The transfer case encoder motor consists of a permanent magnet (PM) DC motor and gear reduction assembly. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case (clockwise or counter clockwise) to shift the transfer case. The encoder motor is controlled with a pulse width modulated (PWM) circuit within the transfer case shift control module. This circuit consists of a driver on both the Motor A and Motor B circuits. The encoder motor is bi-directional to allow the motor to shift the transfer case from 2HI or 4HI to NEUTRAL and 4LO positions.
Do you know what DTC'S are ?
DTC B2725 ATC Mode Switch Circuit Malfunction
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0308 Motor A/B Circuit Low
DTC C0309 Motor A/B Circuit High
DTC C0310 Motor A/B Circuit Open
DTC C0315 Motor Ground Circuit Open
DTC C0323 T-Case Lock Circuit Low
DTC C0324 T-Case Lock Circuit High
DTC C0327 Encoder Circuit Malfunction
DTC C0367 Front Axle Control Circuit High
DTC C0374 General System Malfunction
DTC C0376 Front/Rear Shaft Speed Mismatch
DTC C0387 Unable to Perform Shift
DTC C0550 ECU Malfunction
DTC C0611 VIN Information Error
Aug 27, 2017 | 1999 Chevrolet Silverado 1500
Canyon 4wheeldrive light turned on
Checking the 4X4 control module for DTC'S - diagnostic trouble codes is what you should done . Need a factory or professional type scan tool , no an OBD2 code reader . Looking at factory service repair info. description of how it works , an testing is how to diagnose . Not guessing an throwing parts at it .
DTC B2725
The accessory switch circuit consists of 4 modes. The transfer case shift control module supplies 5 volts to the switch through the switch signal circuit. The current travels through the resistor of the currently active mode. The current on the switch signal circuit is monitored by the transfer case shift control module. The voltage on the switch signal circuit will vary depending on which mode button is pressed by the driver.
The transfer case shift control module constantly monitors the switch signal circuit to determine the condition of the accessory switch circuit.
When each of the modes are selected they complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch signal circuit to determine whether the Neutral, 2HI, 4HI, or 4LO mode was selected by the driver.
The transfer case shift control module has 4 encoder circuits, and each circuit is supplied 12 volts. These 4 circuits are A, B, C, and P, and each circuit runs to a switch located inside the encoder/motor assembly. When a particular encoder circuit is active, the switch is closed, and the 12 volts are grounded by the switch inside the encoder.
The transfer case shift control module supplies 12 volts on all the circuits. The module can interpret the location of the transfer case shift position when the circuits are grounded.
This DTC detects a fault when it compares the shift sequence/strategy to a chart located in read only memory (ROM), within the electronic control unit (ECU), within the transfer case shift control module. This is accomplished by the module reading the different combinations of encoder signals being grounded while others remain high depending on what mode or range the transfer case is in.
At each power-up, the transfer case shift control module runs a self-test on the following functions:
• EEPROM Checksum
• ROM Checksum
• RAM Checksum
• RAM Malfunction
I suggest your take your vehicle to a qualified repair shop .
Dec 31, 2017 | 2005 GMC Canyon
My 1999 chevy silverado 1500 four wheel drive won't engage. The truck is in 2wd now. When I push 4wd hi or low, I can hear the actuator try to engage the four wheel drive. The four hi or low button will...
You probably have a bad encoder motor.It is located on the side of the transfer case on the drivers side.It is black.The other problem they had with these was the switch but you have already replaced this so your next thing is the encoder motor.Hope this helps.Good luck.
Dec 28, 2009 | 1999 Chevrolet Silverado 1500
BLACK AND DECKER HANDI SAW ISNT WORKING
there are several trouble shooting you can perform:
1. Check the plug particularly teh wire attached on it.almost all of the wires of a power tools got damage on the wires itself due to a continous moving when working.
2. Somtimes there is a built-in fuse or breaker.
3. Check the Switch.sometimes the spring materials of a switch is malfuncioning and it couldn't connect the conductor to run a power.
4. Check your carbon Brush.You must replace it if it is already below 1/4 inch long.
5.Can you feel a little vibration when you switch the unit?if that so,check the bearing because it is surely the bearing has damaged because the armature and core of the motor is already touching each other thats why it will not rotate anymore..
Oct 30, 2009 | Black & Decker Cordless Handi Saw
4 wheel drive switch always on auto 4 wheel drive
need to take vehicle in to get scanned, if p0327 code is present and oil inside of encoder motor, will need a new encoder motor sensor and bearing, will have to remove the t-case to install.
Oct 04, 2009 | 2005 Chevrolet Tahoe
Chevrolet Suburban 4 Wheel Drive Indicator Lights
Just serviced my own 4x4 Suburban, by buying a 2nd hand encoder motor and replaced the old one, which was trashed by the winter salt. The device is prone to failure since it's made of alluminium and water has an easy time of entering the unit and trashing it.
CAUTION: Abbreviated gratuitous information of how an encoder motor was serviced. If unqualified to deal with repair, seek professional service.
CAUTION: Read at one's own risk.
To replace it, you need to crawl under the vehicle and remove the front drive shaft;
Disconnect the electric harness to the encoder motor, followed by unbolting it.
Take replacement encoder motor and install. There may be an issue with aligning the cogged cam of the transfer case to the encoder motor. If so, the vehicle's 4 wheels will need to be raised off the ground. The engine started, transmission in Park, and using a Vice-Grip® wrench gently rotate cam clockwise approximately 1/16 to 1/8 of an inch, then while set in this position, stop engine. Now attempt to align and attach the encoder motor.
After successfully attaching new encoder motor, attach its wiring loom.
Test vehicle.
Mar 22, 2009 | 2003 Chevrolet Suburban 1500
Denali slips in and out of 4x4
How may buttons for the 4X4 two , three , or four ? Do the lights flash ? Any messages - service four wheel drive system ? Which transfer case does it have ?
Transfer Case - NVG 246-NP8 (Two Speed Automatic)
The transfer case encoder motor consists of a permanent magnet (PM) DC motor and gear reduction assembly. It is located on the left hand side (drivers side) of the transfer case. When activated it turns the sector shaft of the transfer case (clockwise or counter clockwise) to shift the transfer case. The encoder motor is controlled with a pulse width modulated (PWM) circuit within the transfer case shift control module. This circuit consists of a driver on both the Motor Feed A and Motor Feed B circuits. The encoder motor is bi-directional to allow the motor to shift the transfer case from 2HI or 4HI to NEUTRAL and 4LO positions.
The encoder is mounted to the transfer case encoder motor assembly and is replaced as an assembly. The encoder converts the sector shaft position (representing a mode or range) into electrical signals inputs to the transfer case shift control module. The module can detect what position the transfer case is in by monitoring the 4 encoder channels (P, A, B, and C). These inputs translates into AUTO 4WD, 2H, 4H, NEUTRAL, and 4L or in transition between gears.
Transfer Case Motor Lock
The transfer case motor lock is used to provide a 2H, 4H, and 4L lock-up feature. When the lock circuit is energized, the transfer case encoder motor is allowed to turn. When the transfer case is placed 2H, 4H, or 4L the motor lock circuit has no power provided to it and the lock is applied. This assures that the transfer case remains in the current gear position. When AUTO 4WD is selected the motor lock remains applied until an adaptive mode (torque is applied to the front propshaft) is required. During an adaptive mode the motor lock circuit is energized and the motor lock is released, enabling the encoder motor to turn and apply torque to the front propshaft.
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via a Class 2 message or by a Sevice Indicator Control Circuit.
The first thing to do before assuming it's a loose wire would be to have it checked for codes , auto zone , advance etc... can not check this codes .
DTC B0768 Service Indicator Circuit High
DTC C0357 Park Switch Circuit High
DTC C0362 4LO Discrete Output Circuit High
If you know nothing about this , your best bet would be to take it to a qualified repair shop .
Apr 29, 2017 | 2000 GMC Denali
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Inverter KEB COMBIVERT F5 Logo
79 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
