Question about Dishwashers
MyGE 24 in. Profile PDW9280JSS Built-in Dishwasher control panel is unresponsive when the door is ajar, but only comes to life when closed.
MyGE 24 in. Profile PDW9280JSS Built-in Dishwasher control panel is unresponsive when the door is ajar, but only comes to life when closed. I can barely reach the Start button, but it does run when pushed. HOWEVER, i cannot change modes or use ny other button. This started after a power outage, but not a surge. I have cycled the breaker. I've tried a long press on the start/reset button. Ideas?
  • 114 Answers
SOURCE: No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Posted on Oct 02, 2007
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 6784 Answers
SOURCE: No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 13, 2009
SOURCE: GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
Posted on Oct 22, 2009
Dishwasher will not operate
How long have you had the dishwasher? Is it just dead??? Are there any lights on the keypad at all? I had the same problem with mine and the answer I got was that it was either the door latch, keypad or the control module...
Aug 23, 2012 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwasher fails to fill with water, will drain correctly if water is poured into the unit
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
Sep 06, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Hi, Should I press Start button first or close the door first and then push the start button? If I do the later, I can't see the control panel, although my dishwasher has been installed 1/2" lower than my...
If you are referring to the style dishwasher that has the controls on the TOP edge of the door, you are supposed to select the preferred cycle and options you wish to use, then press START while the door is OPEN. You will then have about 3 seconds to close the door. If you fail to shut the door in the allotted time, the program will cancel and you will have to repeat the steps. This information should be printed in the owner's manual under the operating instructions.
Jul 01, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
