Question about Hoover Vacuums
I have a Hoover power head vacuum cleaner. When I turn the power head on it makes a squealing sound
  • Hoover Master
  • 10,291 Answers
The bearings at the end of the roller brushes need lubricating. The belt may be too shiny to be useful now so replace it after you lube the brush
Posted on Nov 20, 2014
reddevil6
  • 1673 Answers
SOURCE: Hoover windtunnel will NOT turn on
You have to remove the motor cover, There I believe 5 screw, take off the light lens and remove the screw holding the light. It should then pull off. You say you have power to the Vac, but do you have power to the motor. There also is a thermo by the motor, sometimes they open up, then the motor won't run.
Posted on Jan 06, 2008
  • 7 Answers
SOURCE: Hoover Model S3755 Parts List Needed
Go to hoover.com and look up a local Hoover store. Give the a call and ask the to mail of fax you a schematic. They should be pretty helpful.
Posted on Jan 07, 2008
  • 46 Answers
SOURCE: LG Cyclone Vacuum Cleaner Model No VKC902H
there is a small belt inside the head ,remove screws and disasemble carefully. and replace /refit belt
Posted on Feb 09, 2008
SOURCE: hoover cleaner model f5865-900
Water won't dispense....how do I fix it?
Posted on Oct 17, 2008
nwj2468
  • 76 Answers
SOURCE: Need to replace power cord on Hoover vacuum.
remove the dirt container and look for screws.
Posted on Apr 19, 2009
I have a DC41. The power head wont turn and is making a squealing noise.
Sounds like your power head is seized or almost seized. Possibly real dirty. take apart and lubricate ends and replace the belt I feel is slipping Hence the squealing.. Clean all parts thoroughly.
Dec 02, 2016 | Dyson DC41
How do you fix a red Hoover windtunnel 2 rewind pet vacuum (model UH70830)? Since me and my 1year old corgi have arrived at my moms place, I've been using her Hoover vacuum cleaner off the hook because...
It sounds like there's a problem between the power cord and the vacuum cleaner itself. Remove the power cord check the connection at the vacuum cleaner and see if something came unconnected
Nov 18, 2014 | Vacuums
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
The head on my Hoover Canister vacuum has stopped working
It sounds like the power connection pins, from the handle tube to the powerhead, are not making connection. The pins could have been damaged when you impacted it.
Nov 20, 2009 | Vacuums
Bearing screeching?
Yes, it could be a motor bearing. Another possibility is the fan could be broken. Remove the bottom plate from vacuum. Spin the belt motor pulley slowly and view the fan. You may have a plastic fan that has broken or something is keeping the fan from spinning. Here are links with illustrations to an online guide. (the links will say "belts" but it will show how to get to the fan). Click the one that best matches your vacuum.
Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Kirby G6 Bagged Upright Vacuum
No Power HOOVER U5018-900 bagged upright Vacuum
Check the opening behind the floor brush for obstructions there.
Nov 09, 2017 | Hoover U5018-900 Bagged Upright Vacuum
Vacuums Logo
85 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
