Question about Car Audio & Video
I have a lightning audio l-11000d amp and it says paralleled internally for 1 ohm min I have 2 4ohm dvc audiobaun 15s do I wire to come out box 2ohms or 1ohm
  • Car Audio & ... Master
  • 10,291 Answers
Depends on how much power the speakers will handle. If the speakers will take more than the amp is capable of then go for 1 ohm, otherwise your 4 ohm speakers will do fine.
Posted on Nov 20, 2014
uge44
  • 226 Answers
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Posted on Nov 19, 2008
  • 37 Answers
SOURCE: amp problem
Some amps very in what will happen first, some will blow the fuse and some may go in protection mode or the sound will come and go.
Posted on Dec 06, 2008
  • 1596 Answers
SOURCE: 2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Posted on Jan 29, 2009
  • 1126 Answers
SOURCE: 2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Posted on Nov 12, 2009
  • 47 Answers
SOURCE: how to wire a concept cd-2410 amp
when u have a dvc sub you have 2 run a jumper wire from one positive 2 the other and the same w ur negative then run ur wire from one of each to ur amp hope that helps u out
Posted on Feb 28, 2010
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
I have an old school autotec xs 1500.1 and need to know how to hook up the outs to make it 1 ohm
Since it is a mono block amp, it depends on your subwoofer (s), and how you wire them to the amp.
Single 4 ohm sub would be just that, 4 ohms.
Single dvc 4 ohm sub, with both voice coils wired parallel would be 2 ohms.
2 dvc 4 ohm subs wired parallel would be a 1 ohm load.
Feb 20, 2015 | Ohm Car Audio & Video
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
Is right use the amp with the x-over in lpf and also with and impedance of 2
If your amo is a subwoofer amp yes you want a LPF. Low pass filters are capable of passing low frequency energy. As far as the impedance of your amp goes check with the manufacturer for proper the proper load. What speaker config do you have?
2 DVC 8 ohms in parallel (voice coils) then series (speakers) are 8 ohms
2 DVC 4 ohm - in parallel (voice coils) then series (speakers) are 4 ohms
DVC is dual voice coil
Impedence for parallel is (Z1^-1+Z2^-1)^-1 or 1/((1/Z1)+(1/Z2))
Use those to figure out parallel impedance, series you just add them together.
Dec 21, 2009 | Hifonics Titan TXi 6006 Car Audio...
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
2 alpine type r 15's 4 ohm dvc and 2 american bass svc 4 ohm and hk401sx how do i get the most beat?
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
How do i wire two audio pipe dvc woofers to this amp. do i use all four terminals on da amp. jl audio 500.1
Hello smoovek2008,
The JL Audio 500/1 outputs 500 watts RMS into a load from 1.5 to 4 ohms. Whether your subs have 2 ohm or 4 ohm voice coils, they should be wired in series and the subs paralleled to the amp. The final load to the amp will be either 2 ohms or 4 ohms, both of which the amp can handle. If you parallel the voice coils and then parallel the subs, the final impedance will be either 0.5 ohm or 1 ohm, both too low for the amp.
You can wire each sub to a separate set of terminals or both to the same set. The terminals are connected internally. It doesn't matter which of the +'s or -'s you use.
Hope this helps.
Sep 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
Speaker connections
This is a single channel amp that puts out about the same power at 4 Ohms or 2 Ohms. If you have two 4 Ohm single voice coil subs, then wire them parallel (both pos and both neg) to achieve 2 ohms. If you have two dual 4 Ohm voive coils, you want to do a series - parallel config to get to 4 Ohms (voice coils in series, then parallel the subs). Same with DVC 2 Ohm subs, series parallel = 2 Ohms. Do NOT go below two Ohms. You will blow the amp (actually, it'll do 1.5 Ohms). If you happen to have 2 Ohm single voice coil subs (not as likely) run them in series. Most amps will put out about twice as much power at 2 Ohms vs. 4, but this amp is designed to put out about the same. Hope this helps!
Feb 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
