Question about Health & Beauty
How can u change my blood pressure cuff from metric to american
  • David Payne
    David Payne Nov 20, 2014
    go buy one in ENGLISH and save yourself some problems that way you have one for the USA and one for overseas.
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
http://www.walmart.com/c/ep/blood-pressure-cuffs
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
www.youtube.com/watch?v=8e6qtnHa8ps
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
How do I calibrate a WrisTech model JB5887 blood pressure cuff?
2ND TIME,YOU DO NOT,,YOU SEND IT BACK TO THE COMPANY!! no user adjustable parts,
Blood pressure measurements taken with the unit are equivalent to those obtained by a trained observer using the cuff / stethoscope auscultation method and are within the accuracy limits prescribed by the American National Standard for Electronic or Automated Sphygmomanometers.
This device is not meant to be a substitute for advice provided by your doctor or other medical professional. This is not for diagnosing or treating a health problem or prescribing any medication.
If you have or suspect that you have a medical problem, promptly consult your healthcare provider.
http://wristechbloodpressuremonitor.com/
Apr 11, 2015 | Health & Beauty
Have HEm-780 and the cuff is too big. how does that effect my readings. Can I order smaller cuff?
  1. You can buy a smaller cuff. Pressure may be wrong also. Most local stores have them.
Feb 10, 2015 | Omron HEM 780 Automatic Blood Pressure...
Neither of the cuffs on the Homedics S18729 Ultra-Deluxe Automatic Blood Pressure Monitor work. They do not fit well around my arm and constantly slip while inflating. I don't know if it is a design flaw...
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Apr 01, 2011 | Walgreens By Homedics Automatic Blood...
Mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Oct 04, 2009 | Mabis Health & Beauty
Missing instruction manual
here is where to get the instruction manuals for the omron healthcare blood pressure monitors. You just select your model number and either view download or print from the website. Good Luck and God Bless!!
http://www.omronhealthcare.com/product/manuals.asp
Feb 18, 2009 | American Diagnostic Corporation 6016...
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
