Cd will spin for about 5 seconds and stop
Machine works but cd will spin for about 5 seconds then stop
    Top Expert:
  • Audio Player... Master
  • 34,153 Answers
The drive has failed. It can't read the disc.
Posted on Nov 20, 2014
How to fix a Sony 5-disc player that will continue to spin and not stop at any disc slot
There are opto's around the edge of the carousel so the machine can count it's position, maybe these are at fault
Sep 30, 2014 | Sony CDP-CE375 5-Disc CD Changer
Whirlpool AWO/D 8708
F07 is a fault with the motor control, probably the triac has failed.
Jun 16, 2017 | Washing Machines
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a wave machine aprox 15 yrs old.If I manually spin the cd once or twice it will read and play but begins skipping on later tracks.Also volume control is sometimes problematic.Seems like it needs an...
Clean lense on cd pickup. Remove spin motor. Spray some WD40 in the bottom of the motor and connect 5 volts dc to motor and spin for a few seconds in both directions. The motor brushes need cleaned off. This works on most all cd players. Reinstall the motor.If this does not fix replace cd assy. Check solder connections on volume control. If ok replace control.I had one of these that i sold for $500.00 on Ebay. Even used there is a demand for this item.
Nov 20, 2009 | Bose Acoustic Wave (32022) 5-Disc CD...
My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Jul 02, 2009 | GE WBSR3140DW Top Load Washer
DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
 Grubhead
Grubhead
