Question about Hardware & Accessories
<!-- from fixya rte -->How do i trace the specifications of a pump? - Hardware & Accessories
  • 5,245 Answers
Usually a pump will have label giving specs.
Other motor resources... checking ohms on the coils, troubleshoot etc
http://waterheatertimer.org/Color-codewire.html#motor
Gene
Water Heater Timers Save Money
Posted on Nov 20, 2014
I just put a new fuel pump on my 2000 chevy cavalier 2.2 and my fuel pump isnt kicking on so vould someone please help me?
check for power and ground at the pump. if your missing power trace it back and/or check relays and fuses. if the ground is bad run a new one.
if it is a power issue let me know and i'll help you out with some more specific info.
Aug 15, 2015 | Cars & Trucks
Fuel pump wiring not getting power
You need to buy or borrow a voltohm meter and check fuses for voltage and trace the voltage to the fuel pump.
Mar 29, 2014 | 1991 Toyota Camry
This is the IMEI no of the phone stolen a week ago. will you please assist trace it.so desperate
There is no way you can get the phone traced unless you have previously installed a security program which can help with tracing it. But specific phones have this feature preinstalled. Provide more details on the phone make and model so i can try to help you.
Hope this solution has been helpful?
Mar 11, 2011 | Cell Phones
Sir please 9580950756.no name and address detail.resion police enquary
I cannot supply any specific information as the number is assigned to a cellphone and the specific data is not publicly accessible. I can tell you that the phone was registered in East Uttar Pradesh in India. The service provider is Reliance Mobile. All of the information I provided you with can be found on this webpage. http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number-location.php?N=9580950756&B1=Submit
Thank You!
Mar 02, 2011 | Cell Phones
Error 49
If the error can be reproduced, use the following sections of this document:
  • Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Nov 03, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
The error "49. FF05 SERVICE ERROR" is displayed on
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
Oct 26, 2010 | HP LaserJet P3005d Printer
The washer will not drain water during the rinse and spin cycle
The pump is not switched on during the cycle and this circuit must be traced from the timer output. However if the drain works well in the last cycle then the pump is alright. Hence the pump circuit switch during the rinse and spin has to be traced and confirmed. Good day
Aug 12, 2010 | GE Washing Machines
How do i change the water pump on a 1999 2.5 v6 chrysler sebring?
Removal:
Drain cooling system, remove the timing belt if necessary. Remove water pump mounting bolts. Separate water pump from water inlet pipe and remove.
Inspection:
Replace water pump if it has damage or cracks to pump body. Check the shaft seal for any leaks as evidence by traces of coolant from vent hole. Check for any impeller rubbing inside pump, and for loose or rough bearings.
Installation:
Clean all gasket and "O" ring surfaces. Install NEW "O" ring on water pipe (wet "O" ring with water to aid assembly). DO NOT allow oil or grease to contact "O" ring. Install NEW gasket on water pump, and install pump inlet opening over water pipe. Install pump-to-block bolts and tighten to specification 18 FT. Lbs. (25n.m). To complete installation, reverse removal procedure.
Hope this helps :)
Oct 19, 2009 | 1998 Chrysler Sebring
98 diamante is not getting any power to fuel pump? started acting like it did not want to start than finally won't start and have tested the fuel pump is fine but no power to it.
First I would switch out the fuel pump relay and try starting your vehicle if you have no luck with that I would take a test light with the key on engine off and trace the circuit from the fuel pump up towards the engine compartment to check for a continous circuit ensuring that the power wire is not severed or has a weak/loose connection or has shorted out with one or more wires. If you still are having problems you may have a problem with the ecu specifically affecting the fuel management system and I would have it professionally diagnosed and repaired if found at fault. If you need any further help let me know
Aug 21, 2009 | 1998 Mitsubishi Diamante
Hardware & Accessories Logo
37 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
