Question about GE Office Headset For Doro Audioline Ericsson Esi Mitel Models 5000 Ip 5010 5020
How do I disable my mitel sx-50 night mode completely?
The console goes to night mode like every 5 mins. you have to manually turn it back to day. even during the day.
Mitel SX-50 System is not posting wakeup calls or smdr
Please refer to the user manual here http://edocs.mitel.com/UG/EN/SX50_ATT_CON_UG_EN.pdf
Also, try resetting the Mitel Server by powering off and back on; typically takes 5 minutes for the phones to come back on. If this doesn't work you may have a ONS Card that needs to be replaced; contact a service technician who can diagnose the issue.
Oct 08, 2014 | Lands Phones
Why my mitel sx-50 shows message on console no communication?
The phone line between the SX-50 console and the main control is disconnected or the console may need to be rebooted (unplug the phone line then reconnect it). If this doesn't solve it then contact your PBX system support person.
Jul 14, 2014 | Mitel Lands Phones
Printer queue is full on sx-50 attendant console
This is explained in the SX-50 system maintainer's handbook, 2 copies of which came with your SX-50 when it was new. However, this is a pretty old piece of phone equipment (30+ yrs) and when these systems were originally set up by outside service companies, it was not unusual for them to take the manuals so that customers would not be tempted to tamper and would call the service co instead. However, all is not lost. There is a very good Mitel support group on Tek-Tips (www.tek-tips.com) On tek-tips the Mitel forum is under Home->Forums->Wiring Closet->Phone Systems->Mitel Networks Solutions Forum. You will need to register in order to post. Hope this helps.
Apr 19, 2014 | Mitel Superset 4015 Corded Phone
My Mitel SX-50 dial pad on console does not work. Help
Look for a button on the console that is stuck down. This will cause the problem you are describing. If this is not the case, you need to get with a Mitel vendor to get the console repaired and refurbished.
Jul 10, 2013 | Mitel Lands Phones
SX-50 Attendant Console Failure
The console uses 3 pair USOC wiring from the console to the jack on the control card. Look at the Mitel provided cable from the console. It should be 6 pin and you can make sure the console is functional by moving it to the cabinet and plugging it in. If it works, you need to cable 432516 straight through on a 6-wire modular plug and terminate it in the same order on a jack where the console is. They must be paired for the long run.
I have a huge non-indexed pdf of an SX-50 if you need it. The console explanation is figure 5-14 of the -200 practice if you have it.
Carl
Mar 15, 2009 | Lands Phones
Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
GE Office Headset For Doro Audioline Ericsson Esi Mitel Models 5000 Ip 5010 5020 Logo
51 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
