Question about Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer
<!-- from fixya rte -->What does error code IE mean? - Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer
    New Friend:
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code.
1) partially or fully closed water supply lines
2) improperly attached supply hoses
3) clogged supply hose filters (on machine and in the hoses).
Posted on Nov 20, 2014
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Jan 31, 2016 | LG WM2688HWM TROMM SteamWasher
Eco bubble WF1124XAC. What does water sensor error (IE error code) mean?
google Samsung washing machine error codes for a list of codes and solutions.
Sep 08, 2015 | Samsung Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
My LG direct drive dishwasher is giving me an IE or 13 error
Hi, according to the owner's manual on mine, "IE ERROR" means it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine. Once you unclog the water hose, you error code will disappear.
Jun 21, 2011 | LG Dishwashers
An IE code comes on my washing machine and when this happens it does not go through the final rinse cycle
Error code of "IE" signifies a water inlet error.
This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on. Also, this means that the washer has not filled with water in 8 minutes.
Hope helps.
Jun 14, 2011 | Washing Machines
Washer displays IE. What does that mean?
is this an Lg washer ie error code is an water inlet error either low water pressure , kinked fill hoses or bad water valve ....
Jan 23, 2011 | Washing Machines
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
''IE'' error code on my LG dishwahser
According to the owner's manual it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
Nov 15, 2008 | LG LDF6810 Built-in Dishwasher
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer Logo
395 people viewed this question
Top Sears Washing Machines Experts
pawnpower
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
