Question about Frigidaire Kitchen Ranges
Is replacing an electronic oven control on a Frigidaire ES330 this easy?
While in the middle of using the oven the display and oven light switched off and there was an audible click that I'm guessing was the gas cutoff to the oven. The control panel is inoperable but the electronic range ignition and gas flow to the range are still working. I'm assuming the EOC needs to be replaced. I found the repair manual online and these instructions for removing the EOC: To remove the electronic oven control: 1.Disconnect power from the range. 2.Remove the back panel from the backguard. 3.Disconnect wires and harness from the control board. 4.Remove the four screws. (One from each corner.) Is it that easy? If I get the replacement part is reversing the steps just as easy to fix this? I'll be sure to keep track of what wires go where. Thanks!
  • Frigidaire Master
  • 9,639 Answers
Yup...It's that easy. You can get the parts from a local appliance parts store or from any of the many sources online... Sit down when you ask how much the panel costs.
Posted on Nov 20, 2014
Testimonial: "Even though this reply is late, I appreciate the quick reply, Lawrence. I called around a couple local appliance parts places before lucking out and finding a new part available from Amazon, and I have Prime, so that was a no brainer, especially the week before Thanksgiving. ----- For those who might read this later, this really is an easy fix for anyone who might be thinking of DIY. I only had two surprises. 1) the screws holding the backplate on were square bits but I had one handy so it wasn't a big deal. 2) the overlay (the part that you can actually see from the front of the stove, with the button labels and surrounding the timer) is glued on to the clock/timer (the name of the part I had to order) so I had to rip it off the old one and now it looks "less than mint", shall we say. A new overlay is $30-40, so totally not going to replace that after spending about $100 on a new clock/timer!"
jyackle5
  • 8197 Answers
SOURCE: instructions for frigidaire oven
an f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
SOURCE: Jenn Aire Model SVE47600W
Thank you so much for this information. I can verify that this procedure worked (at least for me). I ordered the part from Digi-Key Corp (it was up to a whooping $.28), replaced the old capacitor, plugged everything back in and bam! A working display. There was a beeping and error message but after hitting the Cancel button on the stove, everything was working.
Note that this fixed the dimmed display only. All the other controls were still working--only the display was off. If you have other issues, this might not be a complete solution.
You need basic soldering skills, a small solder iron, a solder ******, and some rosin-core solder. The capacitor is labeled on the circuit board.
When taking the unit off the control panel the largest ribbon cable was clear plastic with embedded contacts. I'd never seen one of these before. The cable's contacts slide in behind the pins on the connector and are held against it by an insert in the connector. When I removed the insert, the clear plastic cable came completely out from the connector. I had thought I'd broken it. But just slide it back in behind the pins, aligning the cable contacts with the pins and put in the connector insert to hold them in place.
The Digi-Key part number for the capacitor is P10292-ND. I ordered 5, just to have a few spares. The 5 caps plus first class postage came to a total of $3.51. Quite a difference from the $160 for the whole unit!
Thanks again to ultigerfan for making this information available.
Posted on May 07, 2009
SOURCE: New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
Posted on Mar 26, 2010
jimmpott
SOURCE: Tappan EOC 316080102/removing circuit board....
Looks like I may have the same problem. Is there an identifying mark for the cap or a location and what value is it?
Posted on Oct 10, 2010
SOURCE: viking igniters door removal?
how do you access those screws with the door still attached; there is no room for a screw driver
Posted on Oct 03, 2012
I have the Frigidaire Gallery slide in stove/oven. The display for temperature is so dim that I can't see it anymore. Would it be a fuse?
The Electronic control has lights inside for the time and for the temperature. Over time the lights get dim (Frigidaires do it a lot). The Electronic control is not a Servicable part. You must buy a new Electronic control.
Apr 09, 2012 | Kitchen Ranges
Error message F!0 displayed
F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Sep 23, 2010 | Frigidaire FEF366DC Electric Kitchen Range
F8 Displayed
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
My Frigidaire FGF354BGWC flashes F1 and beeps
Electronic control has detected a fault condition. Turn the Temperature Control Knob to OFF,
and disconnect the power to the range. Wait 30 seconds and reconnect the power. If fault
Dec 17, 2008 | Frigidaire FGB24L2A Gas Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Kitchen Ranges Logo
119 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
