Question about Garden
The timing on my poulan how do I set it ? - Garden
  • 2,355 Answers
There is no timing on a chainsaw
Posted on Nov 20, 2014
Poulan Pro blower BVM200vs won't start. No spark, changed coil, now I have spark, gas flow good. Tried grounding kill switch to engine & tried removing switch. Do magnets need 2 B indexed to shaft?
The flywheel should have a woodruff key on it, which fits in the groove on the crank shaft. This means the timing is pre set. When setting the timing gap, use a business card between the magnet on the flywheel and the ignition module, tighten them in that position and remove the card.
Is fuel getting into the cylinder and actually wetting the plug.?
Do you have good compression?
May 22, 2016 | Poulan Garden
How do I adjust timing on a poulan pro snowblower
Factory Set, you can not truly adjust the Timing, most people find that the Carburator or Spark plug will fix 99% of everyone's problem
May 13, 2014 | Poulan Garden
Poulan pro bvm200vs, what is the spark plug gap suppossed to be set at?????????????
re: "The plug should be set from the factory check your manual for the gapicon1.png setting"
Chris, If people had the manual do you honestly think they would waste their time looking for the answer online.
Chris - I hope you don't get paid for offering 'Check your manual' answers.
Feb 19, 2011 | Poulan Pro Gas BlowerVacuum ()
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
17 hp poulan mower 42" deck wont start
Recheck the valve lash sometimes they are set too tight. Do a compression test if the valve are set ok. If it indicated lower than 80 psi it may be a burn out valve.
Jul 20, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 33cc 14 inch poulan chainsaw and its' flooded? Help
Check the muffler for dirt dobber nest etc. This is many times the problem with all types of engines after setting for awhile. Another is to replace the plug no matter how good it looks.
Apr 11, 2009 | Poulan Garden
36cc poulan chainsaw carb settings
Poulan does not give the settings but they do give a toll free number to contact if you need help and that is 1-800-554-6723. Sorry I couldnt get more but that is all I saw
Feb 17, 2009 | Poulan Garden
Gap setting poulan wildthing blower
buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Dec 06, 2008 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
