How do I find out if something is true or not?
  • 2,355 Answers
Research
Posted on Nov 20, 2014
Is it true that we know nothing about Obama?
No, it is not true that we know NOTHING about Obama, so now you know something. I hope this helps:)
Dec 13, 2016 | Computers & Internet
Change true false to yes no in SQL Query
This depends on the flavor of SQL you're using. If your column for true/false is boolean then the following would be one method:
SELECT CASE [Column] WHEN true THEN 'Yes' ELSE 'No' END
for something like MS Access:
=IIF(Column = True, "Yes", "No")
Jul 15, 2013 | Computers & Internet
Do true kegerator parts have to be replaced with true parts
Depends on what part you are looking for. I use condenser motors, evaporator motors, thermostats, and even compressors and capillary tubes that I sometimes get at local suppliers. If you're looking for gaskets, hinges, panels, tap heads or something like that it may be easier to get from True.
Dec 31, 2012 | True Direct Draw Systems: Kegerator TDD-3
When I try to print something from my Mac running OS 10.6.7 i get the message that a pipe is broken, and all that prints out is a Error: Syntaxerror OFFENDING COMMAND: true cvt 0fpgm glyf ...
Hi, From what I can make out, you have a corrupted font. The 'true cvt 0fpgm glyf' part refers to a true type thingie The /sfnts is a Mac-speak for system font.
Try the Mac forums for the font issues. Good luck.
Sep 12, 2011 | Xerox Phaser 6180N Laser Printer
What does juniper: true alarm true value mean?
Call your fire panel representative. I have seen this problem and consulted with the factory. It has something to do with the program loaded into your system.
Mar 01, 2010 | Simplex Computers & Internet
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
If formula with umber value
=If(l19<0,l19-l15,"L19 is zero or above")
It would be something along the lines of that. The If statement returns the true value first and then the false value ie
=If(condition,True,False)
So if the condition is met then it is true so it will return the true part and if its false it will ignore the true part and return the false part.
May 06, 2009 | Microsoft Office Professional 2007 Full...
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
May 03, 2009 | True Refrigerators
No sound for chessmaster 10th edition
You need to go to http://forums.ubi.com/eve/forums/a/tpc/f/760105752/m/5081052236 and download all patches in order.
If that doesnt work you will need to search the program file tree (Ubisoft/Chess/Data/User or something along those lines) for a CMDefault.ini cm.ini or YourName.ini (denoted by a notepad with a yellow gear superimposed) first MAKE A COPY OF THIS FILE AND NAME IT SOMETHING ELSE, then open the origional, and look for a modifer such as
sound=
or
playsound=
Or something like that...
If it is set to 0 or false then all you have to do is set it to 1 or true
THE SAME WAY IT IS WRITTEN
so if you see for example
sound=0
you will put
sound=1
NOT sound= 1 or sound =1 or sound= 11
Same for true / false
You also may see it either way
sound=true
sound= true
Save and try it, if the program crashes or fails to load, you made a mistake, delete the INI file and RENAME the COPY to EXACTLY the title of the ORIGIONAL.
And you'll be back where you started.
Mar 26, 2009 | Ubi Soft Chessmaster 10th Edition
RE: true T-49
check the hinge position it's probably off line
Jul 22, 2008 | True T-49 Side by Side Refrigerator...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
