Question about Dodge 2002 Grand Caravan Sport
Where is the HVAC fuse
Did radiator flush,, new thermostat..have switch on hot for heater but it blowing cold air
  • janet duncan
    janet duncan Nov 21, 2014
    if and how do I do this???? PLEASE. I tired of being cold
  • 22 Answers
Probably have an air block bleed the sir out of the system
Posted on Nov 20, 2014
Testimonial: "Thank you. how do I do this?? PLEASE. I tired of being cold"
  • janet duncan
    if and how do I do this?? Please..tired of being cold
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
Need help.. I have a 2001 Dodge Ram 1/2 ton truck.. heater will not get hot.. changed the thermostat..had the radiator flushed.. checked heater coil (sp).. checked the air conditioner flapper door to see...
1 check,Feel the heater hoses,do they get hot ,both or one?They should be hot,if not flush the heater core directly with a hose,back and forth at each hose connection.
2nd check,clamp off the top rad hose and force the hot water through the heater and check heat output.If there is heat with top rad hose clamped change the thermostat,it's either leaking or defective,new or not.
Jun 01, 2017 | Cars & Trucks
Got hot no heat blowing cold air
Heater core blocked or its bad but make sure u have antifreeze and not water in the radiator this will make it blow cold make sure radiator is full check fluid
Jan 06, 2014 | 1992 Geo Tracker
My 2002 buick lasabre heater blows cold.
Assuming the cooling system is full and there are no air pockets, are both heater hoses getting hot when the engine warms up ?
If so, it could be a blend door problem under the dash.
Dec 13, 2012 | Cars & Trucks
The heater is blowing cold air
Check heater hoses running from the engine to the cabin. and check if heater switch works
Nov 28, 2012 | Cars & Trucks
The truck 2005 ford 350 the heat is not working is blowing cold air
Check for correct coolant mixture. Also you could have a thermostat that is stuck completely open causing it to flow straight threw the engine block, cylinder heads, heater core, an radiator without stopping long enough to heat the coolant up to provide cab heat. It could also be a clogged heater core. Or a blend door on the HVAC box that is not allowing the heater core door to open. Hope this helps.
Nov 27, 2012 | 2005 Ford F 350 Super Duty
Drained radiator added prestone Radiator flush refilled and started overheating, drained radiator replaced thermostat and now I get no heat from heater,Radiator water is hot
disconnect the heat hoses going into fire wall , put hose into one with pressure and flush as it sounds like it could be bloked in the heater core,the other thing that could be the problem be the hot ,cold switch as it restricts the flow to makes the heater hoter or colder , it might need tlc or replacing as it is manaul not elec
May 08, 2012 | 1995 Toyota 4Runner
HVAC blows cold air
Try flushing the heater core.You know the hose they can reach operating temperature,but sometimes the core itself is just plugged
Mar 12, 2012 | 2003 Buick Regal
Heater is blowing cold air
Check the heater core hoses with the engine running at operating temp, If there not 200 degrees each then you need a new water pump and thermostat and system flush. if there hot then you need a new blend door actuator located on the HVAC box behind the dash on the passenger side.
Oct 07, 2010 | 1998 Ford Taurus
Heater will not blow hot air. it blows cold air and fan blows. new thermostat and full radiator
The heater core is possibly blocked or the temperature adjuster is not working.
First check the controls to be certain that the temperature aduster is working and the flaps/doors that direct the flow of hot air are working.
If they are..........
Check heater hose temp. If one is hot and one is cold, you are not getting flow through the heater core.
Bleed it to remove an air blockage.
If that does not work, flush the system.
If that does not work, replace the heater core.
Karl at topgunwon.com
Feb 18, 2010 | 2002 Ford Explorer
Open Questions:
See all Dodge 2002 Grand Caravan Sport Questions
Dodge 2002 Grand Caravan Sport Logo
71 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
