Question about Boating
How do I repair the charger portion of the unit without replacing the entire unit
Don't know where to start
  • 46 Answers
No make and model # makes answering difficult so I'll have to give very general information. Also I'm assuming this is well out of warranty - otherwise call the manufacturer first. Now, when we start without any schematic we trace backwards from where we know the circuit should end. In this case you start at the battery terminals since you're trying to find the charging circuit. It is more difficult today since if there's a microprocessor in the mix it could be controlling when a given line is active, when the charging line is connected to the battery, or not. The charging circuit will be a constant-voltage circuit for Li-Ion batteries ~ 3.7 Volts depending on the battery. If it is Lead-Acid it will probably be 13.8 - 14.0 volts, if Ni-Cd or Ni-MHd then it depends on the size of the battery pack and again will probably be a max voltage of about 1.25V/cell * Number-cells. Once you find the circuit you can test to see if there is any output voltage and current when it is "on" - if it never turns on then the problem is either the circuit is dead or the CPU is not turning it on - if the CPU controls this. If you can find the line from the CPU to the charging circuit see if it ever changes state, if not you could try "forcing" a different state, ie, it the state is always off (usually a 0 Voltage) then try finding the voltage line to the CPU and place that voltage on the CPU to Charger circuit line. If the line is always high (anything from 3.3 V to probably 5V depending on the CPU's power requirement) then try lowering the voltage to a 0 state. This is much more difficult since it may require cutting the line from the CPU to the charger. If either of these gets the charger to work then the problem is with the CPU, if nothing gets the charger to work the problem is the charger.
Posted on Nov 24, 2014
Hoover linx battery, charger or unit itself?
As a former owner of one, my suggestion is that it be discarded rather than repaired.
Jan 01, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
How do I repair a broken fuel gauge in 1997 Buick Riviera? Is it in the top of the gas tank and is it accessible without replacing fuel pump?
if your talking about the unit in the tank and not the dash unit then you will have to drop the tank and remove the unit from the tank.you can buy just the sending unit portion of the unit and not have to buy the entire pump unit with it.however if this is the original pump assembly then i would recommend that you replace the entire unit as it will more than likely need replacing shortly after repairing this problem.check to make sure its not a bad wire connection problem.
Jul 11, 2011 | 1997 Buick Riviera
When i remove the charger from my pc(acer aspire one zg5) the notebook just shut down, i was told that the battery is deadand must be replaced, so i want to ask if there is any way i can fix it again...
the problem you have can be one of two. 1 the battery is dead and needs replacing to use it without the charger plugged in 2 the charging circuit in your laptop has failed and will not charge the battery As the laptop works when plugged in then I would guess it's the battery. If the battery is dead, the only way you can repair it is to open the battery case and replace the individual cells which can be dangerous if you don't know how to handle the cells properly. I would recommend buying a new battery before trying to repair it if you really need one.
Jul 03, 2011 | Acer ASPIRE ONE ZG5 COMPATIBLE LAPTOP LCD...
When i try to power up my unit my "screen" says SAFE and will not respond at all ??
Hello
What is the brand name and model number of your device? Without it how can I post a solution to you. Send these details to me by FixYa please.
May 27, 2011 | Televison & Video
HOW TO OPEN CASE OF MS3 2000 TO REPLACE BATTERIES
The MS3-2000 was not designed to be opened. The case is glued together on the sides. It cn not be disassembled without causing damage to the case
Instead of trying to replace the batteries, I suggest that you change out the entire handle portion of the shaver called a 'lower unit'. It is very cost effective. You will find a compatible lower unit at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 19, 2010 | Remington Health & Beauty
Braun shaver 7505 trimming blade slide will only move between position 3 (trimming) part way to 2. It will not go to 2 or 1(off). This happened suddenly. Shaver operates with cord, but must be unplugged to...
The trimmer and on/off switch are part of the same mechanism. The problem is that the switch apparatus is broken and preventing the trimmer from sliding up. You can't repair it without replacing it.
This is a hard part to find for your model and I don't know where to direct you to purchase one.
I have another suggestion which will be a good remedy especially if your shaver has original batteries and is over 3 or 4 years old. This suggestion is to replace the whole 'lower unit'. This would be the entire handle portion of the shaver. You can upgrade to a nicer model at the same time. Take a look at this compatible lower unit at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7680-syncro-lower-unit-p-642.html
Feb 13, 2010 | Braun Health & Beauty
Tom tom 300
If the battery fried, then you will need to replace the battery, this most likely happened if the charger was a higher amperage than the unit can handle. But in reality, anything could have broken, including capacitors on the chipset itself, which would require replacing the entire chipset inside the system. I would suggest bringing it to an electronics repair shop for a second opinion, but you may need to buy another unit.
Mar 02, 2009 | Tomtom GO 300 GPS Receiver
Minolta CF1501 Duplex Unit problem
yes you can use it without using the double sided option single only to repair need to replace door you can get a used one not so much $ call me 310-930-6348
Jan 02, 2009 | Minolta CF1501 Copier
Battery don´t work
try to replace new battery charger.
Feb 22, 2008 | Astar Trent PD-3070
Boating Logo
85 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
