Question about Sewing Machines
I don't think my pressure foot is down enough or maybe something is wrong with my feed dog, but I am able to move the fabric every-which-way while it is stitching, resulting in a crooked stitch line.
I have fiddled with the feed dog and the pressure foot. I actually don't think that is the problem. I would appreciate any insight into this frustrating problem.
    Novelist:
  • 143 Answers
Without knowing the make and model, it's hard to say, but some machines have an adjustment to change the pressure being exerted on a presser foot. It is 'presser' foot, not pressure foot.
Some have some sort of knob on top, roughly in line with the needle that you either turn or push down.. some have a dial inside the side door with a few numbers on it, that may start at 0 and go to 3 or 4. If the pressure adjustment has become set at 0, then you get what's happening with yours, being able to pull the fabric like you can.
If there isn't any knob or dial to change the pressure, then it may be the feed dogs need adjustment or the bar that the needle and presser foot are attached to needs adjustment, and that wouldn't likely be a fix you can do yourself unless you are very handy with mechanical things.
Some machines also have a lever or switch that allows the feed dogs to be lowered out of the way. If yours has this, it may be stuck in a position below being all the way up, and that might be the issue. A feed dog switch is usually at the front of a machine, low down, not too far from the feed dogs.. but without knowing what machine, hard to say where it might be exactly. But check for both these things.
Posted on Nov 19, 2014
  • 1 more comment
  • Bonita Buerge
    Bonita Buerge Nov 20, 2014
    Thank you, Karen. I think I fixed it (thanx to your detailed suggestions-the button on the top needed pushed in), at the very least it is improved, although I can still move the fabric around some. It is a Necchi Heavy Duty Model No. 3205FA. I've never used this site before and I was delighted to find an answer waiting for me when I checked. :)
  • Karen J Gray
    Karen J Gray Nov 20, 2014
    Pleased to have been of assistance.
  • Karen J Gray
    If you don't have a manual for it, you can often find them online. Put the word Manual plus the make and model number into Google, you may find a source for a manual. That might help you fine tune things. You really shouldn't be able to move fabric when the pressure setting is at the highest level.
  • 201 Answers
SOURCE: Free Motion Sewing - Jams
I don't have a solution, but wanted to remind users of this machine that it does not do the proper free motion action until you reach a certain speed. This information is on page 26 of my manual (older machine, so page no. might have changed with newer manuals). You can stitch at the lower speeds, but it does not "hover" and allow you to move the project swiftly and smoothly.
If you can sew regular sewing without thread/bobbin issues, then it is probably something to do with how you have set/threaded/used the free motion to cause the stoppage. Make sure you have a sharp (i.e. new) needle of the correct size for your thread, that the bobbin thread is the same weight thread as the top thread. Turn on the Needle Down button. There is a Free Motion setting in the Set menu, but I have no idea what it does. I turn it on anyway, just in case! What foot are you using? If you don't have one of the free motion feet (there are quite a few to choose from!) use the embroidery foot (small clear plastic one).
Pam
Posted on Apr 15, 2008
advacak
  • 125 Answers
SOURCE: Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Posted on Dec 02, 2008
mazzion
  • 5 Answers
SOURCE: feed dogs aren't advancing the fabric
try turning the pressure up on foot
Posted on Sep 18, 2009
RichSew
  • 191 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
SOURCE: singer 1425-
When my Singer model 1425 wouldn't guide the fabric, the problem was that the gears were worn out. A very nice sewing machine repairman who's now out of business told my husband how to do it and we saved a lot of money!
Posted on Sep 17, 2010
I have a brother ls 2020 and it will not feed fabric through. I am thinking my feed dogs are messed up but i don't see anything about lowering or raising them. Will I have to take it apart?
According to the manual, your machine does not have the capability to drop/raise the feed dogs. Instead, there is a cover plate that is installed over the feed dogs when performing darning or free motion quilting.
Check that your stitch length is set high enough to actually move the fabric. Some machines also have a presser foot pressure adjustment that will increase or decrease the amount of pressure the presser foot applies to the fabric and the feed dogs. If your machine has this adjustment, it may help to increase the pressure so the fabric will move better. Another thing to check is whether you are using the correct presser foot that will actually rest on the feed dogs.
Reading the hints on pages 28 and 29 may be helpful.
User Guide Manuals LS 2020 Others Brother
Another possibility is that the feed dog points have been worn off. When the points are worn, they no longer grip the fabric like when new. When stitching, be sure to never run the machine with the presser foot setting directly on the feed dogs, it without fabric.
Jan 05, 2018 | Brother Sewing Machines
Janine Jem platinum 760, ,needle just going up and down, have cleaned and checked feed dogs are up and moving help what's wrong, are the dogs too low is there a adjuster can't find it ?
Make sure the stitch length is set high enough to actually advance the fabric--the feed dogs actually need to move forward and backward.. The stitch length control controls how much the feed dogs move the fabric. Also, check if your machine has a presser foot pressure control. This manages the amount of pressure the presser foot applies to the fabric, causing the feed dogs to grip the fabric in their movement.
If these do not resolve the issue, you may need to take it for service.
Mar 10, 2017 | Platinum Sewing Machines
My fabric won't feed
Check that the feed dogs have not been dropped for darning or free motion quilting. If the feed dogs do not rise above the needleplate, they will not pull the fabric through the machine.
Feed dogs do wear (which is why one should always sew with fabric against the feed dogs--never on bare metal).
Something else that happens is that gunk builds up between the teeth of the feed dogs so that they no longer have the grip they need to move the fabric.
Another thing to check is the presser foot "pressure." A lot of sewing machines have a pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and feed dogs. (Consult your owners manual.) he pressure can be adjusted according to the type of fabric being sewn.
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
sewing patternreview com
Sep 04, 2016 | Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
I have a Singer Stylist 533 and the feed dog isn't working properly. It is not jammed because if I turn the handle to use the machine manually I can see it moving below the presser foot. However, once I...
This could be a couple things. First it could be your presser foot pressure is not high enough or the presser bar is sticking and not pushing on the fabric properly. Second it could be broken feed gears. To check this remove the needle and foot and place a finger on the feed dogs. Then turn the hand wheel and feel if the feed dogs are still moving with the pressure of you holding them down. If the stop moving the you most likely have a broken gear or two. The first problem could be resolved by adjusting the setting of the needle bar pressure or oiling the bar if sticking. The second one needs a sewing machine repair person,
Sep 13, 2013 | Sewing Machines
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
My feed dogs are raised but the machine will not feed the fabric fast enough even set at 5
Obvious things first:
is the pressure foot lowered to hold the fabric down?
Are the feed dogs clean and not blocked up with lint?
What stitch length have you set the machine to (if this is what you mean by "5" then that's not it obviously)
Is the machine in a buttonholing sequence or something similar?
Are the feed dogs moving at all in the stitching sequence? Raise the pressure foot and without fabric or thread manually turn the flywheel towards you and watch them moving. Are they coming up above the surface of the needle plate during their sequence.
If they are not moving at all, good chance a gear in the lower shaft has failed.
If they are moving but not coming up above the needle plate enough to move the fabric backwards, then they need adjusting to the correct level.
Sep 03, 2011 | Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
