Question about Electrical Supplies
My generator is an onan 4000... It was starting and running fine and then it wouldn't start anymore. It would try and try. Then I realized the ground wire going from the generator to the power converter box inside the cabin was hot and started melting/bubbling. A election buddy of mine looked at it and suggested that I change the wire from a 14-2 to a 12-2. I did and still the same issue. Tries to start but won't and the wire is getting super hot. Any ideas?
    Scholar:
  • 100 Answers
It will not start because the generator is overloaded before it is even started. I suspect there is a short circuit in the power converter. Disconnect the converter and see if the engine will start then. If there is serious overload when you reconnect, you will know where the problem is. It will probably trip a breaker or blow a fuse then. If you narrow the problem to the converter, write back and I can help you with this too.
Robert
Posted on Nov 24, 2014
  • thomas mccauley Nov 25, 2014
    I actually just connected an extra ground wire from the generator straight to the frame of the rv and it started right up with no overheating of the wires.
mamicheddy
  • 79 Answers
SOURCE: Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Posted on May 09, 2009
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
cmcduncand
  • 714 Answers
SOURCE: the onan generator will not start 4000 KY----looks
If it is clicking it may not be bad, Sight unseen. Your problem is a low battery.
R/
David
Posted on Jan 21, 2010
  • 332 Answers
SOURCE: I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Posted on Mar 07, 2010
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 generator
Check the rotor slip rings and brushes first, the rings should be clean and bright
Jun 24, 2013 | Watts Onan Portable Generator - 4000 ,...
Sensor de aceite de un onan cummins rv QG 4000 generator 4000w
If it runs while start button is pressed but stops when you let go?
Check the rotor bruhes, slip rings are clean on the rotor. If you want to get deeper check and ohm the resisitance of the rotor, and stator both for continuity and ground shorts. Check plugs and wiring on control board. Failing that replace control board
Nov 18, 2012 | Onan Cummins RV QG 4000 Generator, 4000W,...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan genset worked fine a week ago
is it an electric start?...if so check battery and/or look for loose battery cable..Ground?...vibration during use could have loosened the cables...the make ready people sometimes do not tighten properly
Jul 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 start good runs only ten minutsand shuts down,starts up
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
Apr 10, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
