Question about LG 60LM6450 60 inch Multi system LED 3D TV 110-220 volts
I need to access the bootloader or be able to load new software on my tv after a failed software update. The TV does not have a serial port so how to you connect the tv to a pc via the jig is it done through the DB15 plug using pins 12 and 15 with 5,6,7 + 8 to ground or will that only give me access to the VGA eeprom. The led flashes 2 times on power on then restarts this is both with power on and in start on service remote.
SOURCE: LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Posted on Oct 31, 2007
SOURCE: PC SYNC OF PHONEBOOK
I CAN NOT SHARE DATA TO MY PC FROM MY LG MOBILE PHONE RD8000 RELIANCE.I PLUGED USB PORT IN MY PC,
THE PC ASK ME INSTALL SOFTWARE CD,WHEN I PURCHASE MOBILE THERE IS NO CD ONLY DATA CABLE,I GOT.
KINDLY GUIDE ME. &REPLY ME
PGOWRISHANKAR,
CHENNAI.
jananiengrs@yahoo.co.in
Posted on Feb 16, 2008
  • 52 Answers
SOURCE: can the service menu for the LG 52sz8d dlp tv be
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Posted on Apr 22, 2010
SOURCE: I have lg flatron l1730s
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
Posted on Nov 11, 2010
  • 3 Answers
SOURCE: Hello I flashed the wrong
did you solve problem with wrong firmware????
Posted on Dec 07, 2010
Why did it freeze during software update?
Here is some help on a Sharp Aquos. You pull the plug and update manually.
Sharp Aquos Firmware Update Issue and Resolution I recently had problems with my Sharp Aquos LC-60LE632U and firmware update 311U1204061. When I attempted to run the Netflix app, I was told that I couldn't proceed unless I updated the firmware. After 2 attempts to update the firmware via the network, I turned to Google and found that this was a common problem. In order to resolve the issue, you'll need to update the firmware manually, via a USB thumb drive. See the following instructions:
  1. Go to the Sharp USA product download site
  2. After you choose your TV model, download the firmware file
  3. View the rest of the instructions found here
Info found here
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1436990-sharp-aquos-frozen-when-updating-software.html
Oct 03, 2015 | Televison & Video
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
Aug 13, 2015 | Mitsubishi WD65737 65" DLP TV
No map info on nuvi 205w
Plug your nuvi into your PC. Go to the Garmin.com website and log into your account to see your map information. You can go to your account and see the map downloads and reinstall it from there. Or you can download their software "Garmin Express" on your PC. Run the software while your Garmin is plugged into your PC and it will check for any updates for you.
Mar 04, 2015 | Garmin nuvi 205W GPS Receiver
Why does display says"please wait". message on screen reads "searching for software. no respose to controls.
under somewhere there is a reset button push for 5 - 10 secs and go from there.
Aug 28, 2014 | Televison & Video
I bought a Panasonic flatscreen model TCP42x1 and I hooked it up and it is locked, how do I unlock it
to unlock, follow the instructions on page 36 of the user guide of this TV. If you do not have a manual, click the below link to view the manual and go straight to page 36 when the manual has finished loading.
http://service.us.panasonic.com/OPERMANPDF/TCP42X1.PDF
If the above doesn't help, please let me know.
Regards.
Sep 06, 2011 | Panasonic Televison & Video
The computer wil not detect the printer via USB to RS-232 Serial DB9 Adapter. I am running windows 7 pro and i have no serial ports on this computer.
control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Dec 17, 2010 | Epson TM-T88III (C420863)
WHAT IS THE PORT UNDER THE HAIER 7 LCD THAT SAYs update HOW DO I USE THIS FEATURE WHAT IS IT USED FOR DOES THIS UPDATE THE TV ?????
This is a Star Trek GNDN USB mini port for the Haier factory to update the firmware (software stored permanently) in the TV.
If you return the set to Haier for servicing under the 90 days labor, 1 year parts warranty, Haier will probably just send you a refurbished unit.
Part of the refurbishment is for the Haier factory to update the software which runs this digital TV.
If you connect your computer to the port with the correct cable, nothing will happen.
No drivers or user mods (hacks) appear to be available.
Nov 16, 2010 | Haier HLT71 7 in. Portable TV
No sound on 90 HD Digital Channel
You need to get in touch with Lg and they will help you. All you need is for them to either post you a usb with software or they can email it to you and you can put it on a usb and put it on your tv via usb port and update the software on your tv.
The frequency for the new channel is not on your tv but they will give you the software to update so it works.
Jul 02, 2010 | LG 47LC7DF 47 in. LCD HDTV
How do i get a software upgrade for my tv
You will need a USB port or SD Card reader on the TV set in order to update the TV's Firmware. (note: some TV manufactures specify what types of memory are compatible with their TV sets i.e. magic gate, etc.)
Use the appropriate storage device for your TV set and go to:
http://www.support.philips.com/support/downloads.jsp?userLanguage=en&userCountry=us
Enter the model number in the search box. It will search for available software/firmware for your TV set. Download it and save it to your storage device.
Insert the storage device into the TV set. If the software/firmware update screen does not come up automatically, select update software/firmware from the TV's menu.
I hope this helps.
Feb 12, 2010 | Philips Televison & Video
Bootload usb init
you need to have the phone reflash to correct this error.
Jun 06, 2009 | Motorola Mobility W375 Cellular Phone
LG 60LM6450 60 inch Multi system LED 3D TV 110-220 volts Logo
240 people viewed this question
Top LG Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a LG Health and Beauty Expert? Answer questions, earn points and help others
