Question about Garden
How do I change auger belt on mastercraft 12/33 Snowblower from 1980s? Thanks ike@muskokaland.com
Too many pins in the way & it seems it should be easier than pulling everything apart
  • 711 Answers
Yes usually, you will have to remove the roll pin with the proper size punch to remove belt. Post a pic. of the unit so I can see what exactly your looking at. if this info does not help.
Posted on Jan 17, 2015
    New Friend:
  • 32 Answers
Look for a tention pulley, spring loaded, you have to hold the pulley while you put the belt on, is this on a tractor
Posted on Nov 21, 2014
trippssmengi
  • 76 Answers
SOURCE: auger on my snow blower won't turn.
First take a look at the shear pins they will be located on the augers going thru the auger and auger shaft, if they look ok then you need to take the belt off, with the belt off try to turn the im peller by hand. If the impeller does not turn then you need to look to see if something is stuck in the impeller or in the auger. If nothing is stuck in between anything then I would have to say it's going to be the gear box. If the impeller turns then look to see if the auger is turning also while turning the impeller. If the auger doesn't turn then it's probably the gear box. If it does turn then you have an issue at the pulleys
Posted on Jan 07, 2009
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
ToolBoxHero
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
  • 1169 Answers
SOURCE: I have a vintage Yard-Man Snowblower (11/33
Although your model indicates it is probably a 1993 model, You should be able to remove the belt cover. There you should find two pulleys. The small one is a two piece unit remove the outer half and slip the over the lager pulley and on remaining small pulley half, re-install outer pulley half and belt cover.
MTD doesn't list the 313 anymore but the info is from the 1995's 315 model.
Posted on Jan 13, 2011
Snowblower auger will not turn. When auger drive engaged, the belt smokes but auger does not turn.
the auger drive gearbox has failed and needs rebuild with new gears and lube
Feb 09, 2018 | Garden
The impeller is turning but the blades are not. Belt seems ok
Depending on your make of snowblower, At the impeller there is usually 1 or 2 shear pins or bolts circled in red. If the impeller and the impeller shaft are turning but the augers are not, the gear may be stripped inside the gear box circled in yellow or the keyway may have sheared between the auger gear and the auger shaft.
Jan 24, 2016 | Garden
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
Sep 09, 2013 | Garden
How do I change ariens snowblower belts
Oct 12, 2009 | Ariens Garden
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
