Question about Korg Music
<!-- from fixya rte -->Why no sound on Korg C4000 Piano - Korg Music
4 Suggested Answers
  • 189 Answers
SOURCE: split two hands for two different sounds
The SP200 does not have any built in ability to split the keyboard between high and low. My guess is that you were seeing someone using this keyboard as a midi controller for a sampler (or sample player) and they had assigned various samples to keys or key ranges. This can be done using Reason fairly easily. The setup would be in the sampler you use however and not the keyboard.
Hope this helps.
bd.
Posted on Jan 05, 2009
  • 17 Answers
SOURCE: korg c-56 struck by lightning.
if your keyboard has been affected by a lightning strike then every semicondutor ( diode transistor i/c ) will be blown ...I know most components are on the mother board but not all ...I reckon cheaper to buy a new one ...sorry
Posted on Feb 02, 2009
  • 5603 Answers
SOURCE: Need help connecting Korg C-303 (Concert Piano)
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
Posted on Aug 29, 2009
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
How can i have dual voice on x5d korg? I lke piano and strings
Just go to COMBI mode.
Press PAGE+. The display may look like this :dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-1.jpg
In the example above, A03 and A49 is a sound PROGRAM number.
OFF and OFF is a Layer 3 and 4, were not activated.
So in our example, we only activate two voices (two layers).
X5D can combine up to 8 voice. To view the Layer 5-8, press PAGE +.
To change the sound of your choice, move the cursor to the corresponding layer, use this button:
then change the value with the slider / value key (YES and NO):
You can also set the level of each layer.
Press PAGE + until a menu appears LEVEL.
Move the cursor and sets its value
May 30, 2013 | Music
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
My korg c26 does not make any sounds intermittently
I have try that but it sound n stop
Jun 19, 2012 | Korg Music
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
I have around $100 to spend on a used digital piano keyboard, and i know nothing about playing, but i would like to learn, like teach myself, i did at one point try to teach myself on a late 80"s Korg...
You will likely have to double that budget to get anything decent... but look for a Yamaha in the PSR series (61 keys minimum). To get a full 88 key, you might have to be up in the $400 range for anything really decent.
Jan 27, 2010 | Korg Ma30
Manuals for Concert Piano Korg C-15
I have a Korg Concert Piano (C-15S) which was working perfectly till about two months ago. I have been on vacation for two months, had left the piano unplugged from the electric supply point, but on re-connecting now, I get no sound from it. Is there a reset button (or other device) that I may have to use? Appreciate your advice.
Thank you,
L. Paul
Apr 03, 2009 | Yamaha Full-Size Keyboard
Music Logo
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
