Question about HP LaserJet Pro CM1415 CM1415FNW Laser Multifunction Printer - Color -
My cm1415 prints fine but has stopped colour copying it just switches to black and white whatever is put on the glass
I have no idea where to start looking so I have tried by turning the power on and off but that is all so far
  • HP Master
  • 1,915 Answers
Do you have an empty color cartridge by any chance or one that is super low?
Posted on Nov 21, 2014
SOURCE: hp officejet 6110 not printing with black ink
I think I know what is the problem. I refilled my black ink cartridge and it printed for a while, but at some point it just stopped working. The head wouldn't touch the paper. Initially I thought the printer had a problem, but then I discovered that the color cartridge still worked.I had a spare new cartridge so I changed it. Everything worked just fine afterwards. My hypothesis is that HP tracks an identifier in the cartridge and does NOT allow you to refill (I even think they simulate for the cartridge to be failing, but I still have to corroborate this). I think this is outrageous and illegal. Please let other people with the same problem know about it. So, the solution is to stop using HP products.
Posted on Dec 05, 2008
  • 166 Answers
SOURCE: When I put a doc on the glass to copy -the print has a black vertical line down the page. When I print from computer to print - it works fine - there is no line of ink. Can I fix this myself? What wou
A long black line on scanned images is usually caused by a piece of trash on the scanning mechanism.
Look at the scanning arm (the thing that moves when you scan something) and then see if it has any trash on it. If it looks good then you may have a mechanical malfunction in that part.
Let us know hat you find.
Posted on May 21, 2009
  • 21 Answers
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
CompuGuy44
  • 432 Answers
SOURCE: printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Posted on Aug 07, 2009
CompuGuy44
  • 432 Answers
SOURCE: Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Posted on Aug 08, 2009
Print in Black and White only
Click Start
Click Control Panel
Click Printers
Right-mouse click on your printer
Click Properties
You should be able to select "black-only", instead of "colour".
Jul 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
CANON MP600 - NOT PRINTING IN BLACK INK
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Apr 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Bought a canon super g3 laser printer approx 8 months ago which prints in black and white. can i put a colour cartridge into this printer?? thank you
Super G3 is not the model. It is Canon's fax technology. It is classified as a laser fax/printer. This is a monochrome printer which means you can print only one colour at a time. You can print all black or all yellow, all red or whatever colour cartridge is available.It has no capability to mix colours. Not any colour (including black) toner will work as the composition is different to suit the printer model. Hope this helps.
Rgds
S88
Dec 19, 2008 | Office Equipment & Supplies
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet Pro CM1415 CM1415FNW Laser Multifunction Printer - Color - Logo
61 people viewed this question
Seeker5211
Seeker5211
