Hover nextra hnf7148 ,water comes out of the back
Hover nextra hnf7148 ,water comes out of the back of the machine when loading with water, it comes from 3 small holes on the right hand side of the belt.i replaced the carbon brushes about a month ago ,I had the machine laying face down for a while. Just wondering if i may have messed up the alignment. ? Please help .
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
There is a big chance that you have messed up. As i know washing machines comes with 3-4 long bolts attached at back of machine. Which secures heavy inner parts during transportation. If you didn't attach those long bolts before laying your machine face down, inner pieces might be damaged.
Posted on Nov 21, 2014
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
Nicesuit
  • 61 Answers
SOURCE: HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
Hi John,
it has been a while since i worked on one of these, but I might be able to talk you through it, first make sure you have the correct bits to replace. i.e. the inside of the handle and the latch match the same that is on that you can see before you go any further.
using a torx size 15 I think remove the two screws on the door hindge, and then remove door by pushing up by a 1/4" then the hindge should pull away from the machine. using a torx size 10 then proceed to remove the four screws from the inside of the door frame, ease the door pannels appart and the glass bowl and lock should be exposed. there should be a further two screws holding the latch in place, just be careful when taken these out as they may be under load from a spring, note the positions of the latch and replace all back in reverse order.
Cheers,
Posted on Sep 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Drive belt came off spindle on Hotpoint First
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Posted on Sep 13, 2009
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
E04
Hello, this code normally means the machine has a clog. It could be a like a small sock stuck in hose drain line, or something small like that.
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these directions upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
I hope this helps, Mike from fixya.
Aug 24, 2011 | Washing Machines
We get the error code eo4 on our Bosch front loader, and it does not spin.
Hi, "E04" means the "suds or pump is blocked"
Bosch E04 Solution:
  7. Read these direction upside down and backwards to put it all back together.
Jun 23, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a siemens front loading washing mashing, the door will not unlock and there is an error code E 04 is this something I can fix or do I need to call for service?
This machine is most likely a the E04 error, which means the pump is blocked.
if in fact its a bosch you will find this should fix the error.
Bosch E04 Solution:
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free.
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
Dec 31, 2010 | Washing Machines
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
What is the error e04
  7. Read these directiosn upside down and backwards to put it all back together.
Aug 16, 2009 | CDA Washing Machines
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
