Question about EasyPak 1000 Flex-Fit Air Spa Control System- EP1000
I have a heat light on my spa control but no heat output. The side of the easypak system has a heat light on it that is not illuminated.
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 | Pool & Spa
My Balboa 300F hot tub will not heat up. I am not able to get it out of economy mode. What can I do?
First, balboa does not manufacture hot tubs! They make control systems for hot tubs. If you are no longer able to switch between modes, then your topside control panel buttons are dead or falling. But... Even if you are still in economy mode, spa should still heat up. Once a demand for heat is recognized, you have a "Heat Call" and heater should come on. Is the "heat on" light, illuminated? If so, water should be heating, if not heater element may be bad? A multi meter would be good here: is there proper voltage at terminals on circuit board to heater? If so, bad element! If no voltage, then heater is not necessarily bad, probably just fine, I would then look at sensors? Good luck
Feb 23, 2015 | Pool & Spa
Problem with jandy rs 4. Pool heat pump Is running. We didn't turn it on and the heat pump light on the control panel is not lit
Does your pool gave an attached spa?
IF it does have a spa, dies it also have a spa side remote?
If so the first step would be to unplug the spa side remote from the back of the board.
If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
Nov 01, 2014 | Jandy AquaLink RS 4 P or S OneTouch Pool...
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
Jandy PDA says service mode no operations allowed here
The system is in service mode. To get it off service mode, go to the power center at the equipment and open the door. On the left upper corner you will see a button labeled "mode". Press it until the little red light is illuminated next to the "Auto" label.
You are all fixed!
Please vote for me!
Apr 10, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
Apr 05, 2010 | 1998 Audi A4
I have a Pentair MasterTemp Heater 250K BTU (i think) Turned on the spa the heat it today and lost all power to whole Pentair Intlitouch system. Reset system but now heater is showing Service Heater. AFS...
try cycling the power to the heater itself. Check for damage (pack rats, etc..). It sounds like you may have had a direct short. It could be a board problem or a transformer problem. If you're still getting the service heater light, check to see if any diagnostic LED is illuminated behind the board.
Dec 28, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
EasyPak 1000 Flex-Fit Air Spa Control System- EP1000 Logo
553 people viewed this question
Top EasyPak Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an EasyPak Pool and Spa Expert? Answer questions, earn points and help others
