Kodak i700 scanner error code 7086 - Office Equipment & Supplies
3 Suggested Answers
spinal
  • 287 Answers
SOURCE: hello i have a canon
Hello earl,
It's not clear to me whether you are talking about 1 device or 2 different ones, as the E19 code would take precedent over the E65 therefore you would not see the second code. I willa ssume you are indeed talking about 2 different devices. The E19 code means the waste toner bottle is full. On this device the waste toner bottle reaches a volume that the weight of the bottle will trip a sensor/switch and will shut the device down. In order to fix this problem we of course need to empty the bottle. Lets establish a referrence point, that being YOU standing in front of the copier. On the right side, at the rear lower quadrant you will see a small panel about 4 inches wide and about 14 inches tall (about). There are 2 screws that will allow you to remove this panel. It has 2 "feet" at the bottom that will help you re position it when you need to put it back. Remove the panel and pull the waste toner bottle straight out and empty it CAREFULLY to avoid a Hiroshima mess. Re-install the bottle and put the cover back on. Ok, now I work on so many copiers that I am not sure the minimum requirements to reset this code. I believe you need to merely power off the device (main power located on the left side halfway down). But if that doesn't work then we can go into service mode clear the error. If you need to, here's how to go into service mode and clear the error. Press the "ADDITIONAL FUNCTIONS" button and release..next press the numbers 2&8 at the same time and release....then press the "ADDITIONAL FUNCTIONS " button again. This should be a fluid 3 step process,1-2-3. Once you have succeeded the screen will change. It will say service mode and you will see several tabs. Touch the COPIER tab. The screen again changes and you will see several tabs across the top of the screen along with "clutter" across the main screen. Select the tab at the top that says FUNCTION. New screen again.Now on the main screen select CLEAR . New screen. WARNING! There are alot of things here that you can "clear". Select ERR and then press the OK button at the bottom of the screen. Now power off the copier and you are done. Now, in regards to the E65. That means the "Primary Charger" is shorting out. This problem begs for a tech to come out as I can't describe to a layperson how to fix it. You could try this. Go to additional functions, and then select ( I believe it is) Cleaning and Ajustment. Once you have selected this look for "Wire Cleaning". Select it. I can't see the screen in my mind but ....you will need to say yes ....OK......Uh huh... execute.....something like that. This will clean the "wires" which when are very soiled CAN cause this code. The E19 I got for you, The E65 is a prayer that may be answered. I hope this helps you earl. Take care, and if I helped (I sure as hell tried) let "FIXYA " know please. :-) SPINAL
Posted on Mar 28, 2011
SOURCE: canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Posted on Aug 06, 2011
Hello ,i have a problem while connecting my kodak scanner i780 ,there is a message<<unable to start scanner,please read the kds.log for more information>> so plz help me so
Did you use the installation software CD-rom before running it on your new computer? Most scanners comes with an installation CD that you have to install before using it. You may also have to restart your computer before using it after the installation. Good luck.
Nov 06, 2014 | Kodak Scanners Kodak I600/I700/I800 Series...
What causes a kodak i700 scanner to keep running?
Could be the setting in the driver (scan validation tool) time out or if the feeder roller continues to turn clean the sensor located on the paper tray inside the square hole approx 8 mm X8 mm just below where the feed rollers are located
Jun 19, 2014 | Kodak i780 Sheetfed Scanner
Kodak U9 error code. How do you clear it?
we are facing problem Kodak i4600 scanner error u9 .we replaced udds Sensor same problem.
Aug 22, 2013 | Kodak Office Equipment & Supplies
Error code e0000110 on 7086
can you pls help me with error e0000110 0000 on ir 7086 thx augustine
Jun 22, 2013 | Office Equipment & Supplies
Microtek i700 won't work with windows 7
Try downloading the drivers at this site: http://bit.ly/eKmyxA
Mar 12, 2011 | Microtek ScanMaker i700
Error Code 7 blinks for awhile then locks on error 7
HERE is the service guide for your printer. the error code you mentioned says to call Kodak support and gives no other info.
Jan 07, 2011 | Kodak i40 Path-Through Scanner
Canon ir 7086 error code e00005-0010
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak I-40 Scanner
8 Face up light check failure is the only code listed, not "88" for this model.
If code 8, the top lamp may well be occasionally flickering. Could be the Lamp or the Inverter (Ballast) check connections to lamp.
Jan 12, 2007 | Kodak i40 Path-Through Scanner
29 people viewed this question
k24674
jasbo
jasbo
