Question about Calligaris Hyper Extension Table CAL-CS-416-XR
I own a Calligaris "Hper" CS/416 extension table with broken plastic parts that broke and fell out of the extension leaves. Does anyone have replacement part information or where/how it can be repair
Model: Calligaris Hyper CS/416 extension table
One end of the table when expanded sags ?
Did you find a solution, mine has done the same?
May 29, 2014 | Calligaris Hyper XR Extendable Dining...
How to disassemble the calligaris planet table
Here is the PDF from the Calligaris website:
http://www.calligaris.com/schede_prodotto/H-A%204005%2001%2000-4.pdf
Feb 11, 2014 | Calligaris 35.5"" Planet Table with...
Calligaris hyper table how adjust level
Manual from the Calligaris website:
http://www.calligaris.com/schede_prodotto/H-A%20416%2001%2001-2.pdf
Nov 19, 2013 | Calligaris XR Hyper Extendable Dining...
Just bought a Calligaris 'planet' table and it wobbles.
Check the legs and frame to see if it is out of square.
Sep 23, 2013 | Furniture
Broken chair castor
the stem does not come out but u can find @office chir parts.com
Oct 09, 2012 | Calligaris New York Office Chair
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
My petrol flap fell off, one of the lugs on the
you can get a new hinge for the gas door at the dealership use a small punch in the center of the plastic rivet tap with a hammer the center will come out after attaching to fuel door the center of rivets are sticking out use 1/4 inch extension tap with hamer until flush and voila
Aug 06, 2009 | Volvo XC70 Cars & Trucks
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
Calligaris Hyper Extension Table CAL-CS-416-XR Logo
718 people viewed this question
Top Calligaris Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Calligaris Furniture Expert? Answer questions, earn points and help others
