Question about Sewing Machines
When I turn my machine on it makes a long rattling sound in the bobbin case area, then when the screen comes on it says to raise the presser foot up and turn power on again. The presser foot is always
I clean my machine frequently. I change the needles after a few embroidery projects. I have a designated bobbin case for embroidery I buy quality thread I've been a sewing instructor for over thirty years and I know the importance of keeping a machine well maintained.
    Novelist:
    Scholar:
  • 130 Answers
How old is the machine ? Sometimes, the 'socket' [ for lack of a better word ], where you fit the bobbin case into the machine, can become worn with use. So the bobbin may be set a bit too low, compared to where it was when new. May cause noise, may cause failure to catch the bobbin thread by the needle.
Sometimes this can be remedied by use of something underneath to shim it up to the right height. But I must say, I haven't ever tried this fix in anything other than a fully mechanical machine.. that is, one that does not have any computer functions. I don't know how it might affect any sensors in the area.
Short of that, might just need to find a sewing machine repair shop.
Often it's just because of a buildup of lint, but you know about that, so that is unlikely to be the reason for this.
Posted on Nov 19, 2014
Testimonial: "My machine is the Janome 11000Se and I have it 6 yrs. The first four years I could hardly embroidery at with the constant thread breaking and thread shredding. It was finally discovered I had the wrong "P" foot (embroidery foot). The one I had came with the attachments with the machine but it wasn't even for my machine. The repair person that has worked on my machine is good and has adjusted the sensor for the latest problem but It seems to go back not being able to sew very long. I had the understanding that the newer machines are not supposed to be oiled and if you do oil them it could cause more noise. My machine also makes an ugly clacking soun when the embroidery arm goes into position. So much has gone wrong that I'm convinced I have a lemon. I just thought that someone might have new insight into this problem. Thank you"
  • Karen J Gray
    Karen J Gray Nov 21, 2014
    Sorry to hear that. Sounds like maybe you do have a lemon.. if you have records of all this, maybe Janome would give you a break on a new machine ? One reason I haven't invested in a computer machine.. I know how to fix most things on the mechanical ones, but not the newer ones.
  • 192 Answers
SOURCE: Designer 1
Please, take this machine to an authorized technician before you attempt to set the timing on your own. An authorized technician will have a device to quickly tell you whether or not the timing is incorrect. If you change the timing yourself and that isn't your problem, you will spend far more money getting 2 problems fixed than the one original problem.
If the machine is making what I describe as a chattering sound, you may be able to clean the bobbin case and the ledge that it sets on and the problem will go away. This bobbin case should be operated with no lubrication. Some repairmen recommend " a drop of oil to make it run quieter". This generally makes it chatter louder. If there is any lube on the bottom of the black bobbin case, wipe it off and wipe the ledge that it rests on.
By the way, if the needle is hitting the raceway, you will be able to see the marks where it is hitting. In a Viking machine, this is normally caused by the "needle to hook clearance", not timing.
Posted on Feb 19, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
mallow1
  • 35 Answers
SOURCE: jI have a Janome 1100,
When you put in the bobbin case, be sure to press it in firmly until you hear it click into place. If you can't press very firmly, or are afraid of hurting your machine, simply lift the latch from the bobbin case, holding it open while you firmly insert the case into the machine. Then release the latch. You should be good to go. Hope this helps!
Posted on Aug 16, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
Gophering
  • 187 Answers
SOURCE: It stopped picking up the bobbin thread while
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Posted on Sep 12, 2011
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
How do I adjust the timing on Brother inovis 1500 sewing machine?
Clean the machine, especially the bobbin and bobbin case area and around the feed dogs. Take all the thread off the top of the machine, including thread off the spool pin. Raise the presser foot. Rethread the top with the presser foot UP, which lets the thread get between the two tension disks. Put the foot down to sew, and hold the ends of the bobbin and top threads together behind the presser foot for the first 2-3 stitches in each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551 I'm betting you're seeing something like the last two pairs of photos.
May 22, 2014 | Brother SE-270D Computerized Sewing...
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Help, my mom is out of town.. I sew two or three stitches and the machine stops. It sounds like it is stuck. I have taken out the bobbin and it doesn't look like anything is stuck?
Get out the manual and start with maintenance so you can be sure the bobbin area is clean.
Now start at the beginning of the manual.
Read and apply as you wind the bobbin and place it into the bobbin case.
Thread the machine - again - read and apply.
Pictures and graphics are very helpful but don't always highlight some of the important steps.
CAN"T FIND THE MANUAL -
Remove the bobbin-case and clean away any thread the may have tangled there.
Make sure the thread is tight and even on the bobbin,
If this is a vertial bobbin/metal bobbin case, the thread winds from the bobbin clockwise and then through the opening on the side of the bobbin case and under the guide just above the opening.
Lift the needle to it's highest position and then lift the lever on the bobbin-case and hold it open as you insert the bobbin-case into the shuttle.
If this is a drop-in, horizontal bobbin, the graphic on the plastic lid covering the bobbin will indicate which way the thread feeds from the bobbin and through the guides.
Replace the needle, with the flat side of the shank facing the back of the machine.
Lift the presser foot and re-thread the machine. IMPORTANT - always have the presser foot up when threading.
Hold onto the thread end, lower and raise the needle to pull up the bobbin thread, Take both thread ends under the presser foot and to the back of the machine.
Place a double layer of fabric under the presser foot. Hold onto the thread ends and lower the needle into the fabric for the first stitch.
Press on the power pedal.
Mar 14, 2010 | Kenmore Sewing Machines
What could cause nesting
With embroidery machines, it is because the bobbin area has tangles of thread.
Turn off the power supply. Raise the needle to it's highest position and then remove the needle plate, bobbin and bobbin case. Clean the area of lint and threads.
Re-thread the machine with the presser foot up - always have the foot up when threading.
If this problem continues, the machine may be out of alignment and will have to go into the shop.
Mar 14, 2010 | Brother Sewing Machines
Machine jammed
Turn off the power and remove the needle and presser foot.
Open the needle plate and bobbin case and clean the area, removing lint and the jammed thread.
Make sure the bobbin case is properly in place.
There is a maintenance section in the manual to show you how to remove the bobbin case and clean the machine.
Install a new needle with the flat side to the back of the machine.
Rethread the machine with the presser foot up.
Make sure the thread from the bobbin is feeding from the bobbin spool in the correct direction and through the proper guides.
If you need a manual, you can download one at Brother.com.
Mar 10, 2010 | Brother CS-8060 Computerized Sewing...
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
