Question about Hotpoint Refrigerators
Hotpoint side by side freezer not defrosting
Recently we changed the switch relay board and also the thermos stat and it worked for about 3 months not the freezer is not defrosting again???
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
Check the timer.
Posted on Nov 21, 2014
Frost free freezer has heavy frost on the back panel?
hi.frosting up could be a number of reasons. try 1-defrost timer 2-heater 3-t/stat 4-pcb .good luck.ali
Jul 12, 2012 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSM25GFTA SA DEFROST PROBLEM
you have a computer board in the back of the machine part number WR55X10942 everything runs through this board.look at this diagram,unplug the machine,remove everything out of the freezer and remove the back inside wall of the freezer,then remove the computer board cover,you'll see like a grey or bluesh looking connector with three pins,this is your defrost,the pin on the left is for the compressor,i unplug the connector,get two pieces of wire,stick them into the grey connector,one in middle and the other in the right side then with aligator clips clip them to the middle and right side post,plug it back in this way the compressor doesn't run,now check to see if the heater comes on,if it doesn't read out the heater with a meter,also if the heater doesn't come on common problem is a bad t-stat,you can cut the two wires going to the t-stat and connect them bypassing the t-stat,plug it back in if the heater comes on then you have a bad t-stat,if it doesn't then you have a bad computer board and change the t-stat.one more thing,there's a sensor on the top of the coil,it looks like a white bullet,if it has a black ring around it where the wires come out of it change it,the new sensor is all white,part number wr55x10025 and the t-stat is WR50X10068 go here to see parts http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSM25GFTASA/1811/0165000?searchedModel=HSM25GFTA&blt=
hope this helps,heater part number WR51X10055,if the heater looks all black inside the glass but reads good with meater change it out it's on it's way out if discolored
Jul 03, 2012 | Hotpoint HSS25GFP Side by Side...
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
HSS25GFPA - freezer frosts over and the refridgerator section gets warm. Had a repair man who said the timer and heater had to be replaced, which he did, but it still does not work. I defrost it by hand...
did he show you the timer?i just looked up your machine and there's a computer board in it,there is no timer.check the defrost thermostat behind the freezer inside panel,also when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,look at the thermostat to see if the top looks like it's popping up,sometimes you can see this if the t-stat is bad or you can cut the wires on it and connect the wire to the heater,and look at your tech sheet should be behind the bottom kick panel to see how to put the machine into defrost,i think you push in the freezer lite switch 5 times or both the lite switches 5 times and see if the heater comes on,if it doesn't i'd read out the heater to make sure it's good,if it is change out the board part number WR55X10942,if you need more help let me know
Mar 22, 2010 | Hotpoint HSS25GFP Side by Side...
Refrig not getting cold ......frigidaire side by side........6yrs old.....freezer temp is fine.......vacuumed coils and rear of fridge...cleared of all collected dust
when you open the freezer door do you hear the fan blowing,could have a bad evap fan motor,also remove the second bin from the bottom and touch the back wall,if there's snow or frost there you have a defrost problem,could have a bad adaptive defrost board in the fridge section or a bad heater,defrost thermostat,take off the back wall inside the freezer,melt out all the ice with hair dryer,check the heater with a meter and t-stat,you should change out the thermostat anyway,you can cut the wires close to the t-stat,connect the wires so you bypass the t-stat,if the heater doesn't come on change out the adaptive defrost board,i think you click the lite switches 5 times to make it go into defrost,if it doesn't it's probably the board,look at the tech sheet behind the bottom kick plate,hope this helps
Mar 20, 2010 | Frigidaire FRS26H5AS Side by Side...
Hotpoint ffa97p - the fridge is too cold and not responding to temperature changing
I'm assuming you're meaning that you reset the "cold control" in the refrigerator area and it is not responding. Try resetting the T stat in the freezer to between 2 1/2 and 3 1/2 and see if the unit continues to run on. If I have this the other way around, set the "cold control" the same as the T stat. The "cold control" is just a flapper door, it doesn't control the compressor only the T stat in the freezer does..
If the T stat is set as I said and the unit just keeps on running and never shuts down except to defrost, the T stat is bad and needs replaced.
There is a chance that the flapper door in the "cold control" is stuck wide open. Removing the cover and inspecting it might tell you if that's happening.
Jul 09, 2009 | Hotpoint Refrigerators
Defrost not working and freezing up, fridge not cold. GE hotpoint model #HSS25IFMDWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Hotpoint Refrigerators
Evaporator fan not working
have you check the thermostat as follows ?
1. operation.
2. circuit from thermo switch (stat) to relay and the function of the relay, the stat should close and coild on relay should be powered, thus closing contacts to pull in evap fan.
assume you are carefull enough not to electrocute yourself in the process, short out relay contacts to see if fan runs. if it does and stat actually is okay. replace relay on board it may be faulty or may have anboard maufacturing fault such as dry solder joint etc.
alternatively if you have a good friend good al electrical work have him relace relay for you.
as an emergency fix , connect evap fan to supply, thus by passing control bard al togheter, ths should give you you 10 degress straight away and keep you rubnning till you solve board level problem.
in the process of changing
asuming you have af
Mar 08, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Open Questions:
Refrigerators Logo
51 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
