Question about Jura Capresso Impressa Z5 Espresso Machine Coffee Maker
I have received this, what this means?
Error 4
That means error 11
Error 11 usually means "Dirty Disc" so you should check that the CD is not dirty and clean it. You can also clean the CD deck (laser) with one of those CD-player cleaning kits. This link explains some of the common errors: Page 36 of Pioneer Multi CD control High power CD player with FM AM...
Aug 04, 2014 | Pioneer Deh-p4400,cd/receiver,mosfet 50 X...
I receive an error code for drain error oe code.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | LG WM2050CW 40 cu. ft. Washer
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
I have a JENSEN CD311X car stereo!
IF THIS PROBLEM HAPPENS TO ALL CDS PLAYED, COULD BE THE OPTICALS LENS IS DIRTY, TRY TO CLEAN IT, OR IF ORGINAL CD CAN BE PLAYED THEN THE OPTICAL LENS ARE NOT PROGRAMMED TO READ THE COPIED ONES
Oct 13, 2009 | Car Audio & Video
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
Error code 6 & error code 4
Error 6 & 4 it means laser is not reading the disc and unforutunally you need to replace the pick up laser assy.
You can get it from pacparts.com,but I reccomend you to take to a proffessional tech because this is a "static sensitive" item.
Dec 08, 2007 | Clarion DX-515 CD Player
Jura Capresso Impressa Z5 Espresso Machine  Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
