Question about Makita Audio Players & Recorders
Makita radio frozen on channel 3 - says dab 3 tuning - no reception??
5 Suggested Answers
  • 7 Answers
SOURCE: tuning of dab radio
Planet rock is quite a small networking station and its outgoing signal is not all that good. Some personal radios simply just havent been made good enough to find a station with such low radio waves. You may just need to buy another or findout over the net the signal of planet rock or weather they've closed down or not.
Posted on Jan 03, 2009
technical114
  • 1851 Answers
SOURCE: makita radio wont tune to 87.6fm
This is a typical setup configuration for US countries; the distance between 2 radiostations is 0.2MHz. If you live outside US it is usefull trying to tune at 87.6MHz because there is no station at that frequency. In case you live outside US try to locate a setting at the tune mode section refered as European countries or Asia countries. At these settings the frequency step is smaller. I'll try to locate a user manual in case you don't have one, in order to give you more detailed steps.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 02, 2010
SOURCE: tune dab to longwave??i cant find long wave on dab
Forget DAB!
Posted on Dec 28, 2010
alchiecez27
  • 641 Answers
SOURCE: why do I have a flashing screen on my makita dab radio ?
check this video.
Posted on May 14, 2014
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
How do i fix faulty dab radio
If your signal keeps breaking up , you might be in a poor reception area , Check if you get the same problem on other DAB stations you are tuned into.
Mar 15, 2015 | Cars & Trucks
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Radio keeps scanning through all stations
Dab reception has frozen on my panasonic radio FM is OK .how do I fix
Sep 18, 2013 | Dewalt DC011 AM/FM Radio
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
DAB RADIO MATSUI MATCR 515D- ILLUMINATED TIME/STATION DISAPPEARED - NO RECEPTION - MUSH CAN BE HEARD IN SPEAKER
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Apr 29, 2008 | Audio Players & Recorders
49 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
