Question about Hitachi Televison & Video
I have an Hitachi (L22DG07U) 22 Inch LED LCD DVD Combi TV that will not turn on, the lights flash between red and blue but no picture.
Changing the batteries in the remote control.
    Top Expert:
  • Hitachi Master
  • 74,482 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 20, 2014
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
cirocpatel
  • 524 Answers
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
Posted on May 11, 2010
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
Green light blinks 3 times
Hitachi p50s601 led blinks 3 times - YouTube
? 2:22
www.youtube.com/watch?v=xM6bpKK0LG0
Jun 28, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click ... flash, but when I remove both boards the TV just runs agreen solid led as if it .... It would show a static then go right back in the 3 blinking blue lights.
Apple TV: About the status light - Apple Support
https://support.apple.com/en-us/HT200154
Apple Inc.Apr 29, 2015 - The Apple TV status light (LED) glows steadily, flashes, or turns off. ...Flashes three times, Rejecting a command from the remote (you've ...
Oct 19, 2015 | Televison & Video
Tv will not turn on after being left on standby
capacitor wearing out on 5v side of the power board, this or these will need changing look for the tops of the capacitors blown up or leaking brown stuff around them and change them for same type ie 10v 487uf dont buy blue type they only 85c temp rating buy 105c rating.
Mar 30, 2015 | RCA Hitachi Le22s314 22" Led 1080p Full...
How do I register the Technika TV That I have just bought?
What is the problem you faces with this TV? Provide more details, please.
Electro help
Electrohelponline
Aug 31, 2014 | Televison & Video
I have a60 inch hitachi projection tv. I tried to fix the screen alignment using the grid but the blue line doesnt move to line up on the grid. The green and red work fine. So theres a blue ghostly glow...
you will need convergence work done & for Hitachi I recommend a professional as the convergence will have to be reset for normal & HD pictures. See if you can get a quote from a local servicer.Be sure you are sitting down.
I really think your money would be better spent on a 21st century LED or LCD TV.
Jul 22, 2014 | Televison & Video
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
Hitachi 60sdx88b
The flashing red light means that the tv is in protection mode. The tv will not turn on when the red LED is flashing. The most common problem for Hitachi are the convergence output ic's. But they useually do not cause the LED to flash. This tv does also have a problem with Q777 going bad. This will cause the LED to flash. If Q777 is bad the horizontal circuit needs to be modified. This must be done by a tech.
Nov 20, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
