Question about Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel
Still getting an error code F1-1 on top oven after repair man replaced Probe sensor on bottom oven. What do I do now?
Repair man wants to come back and replace bottom oven sensor. Bottom is working correctly. So I am confused ,does this make sense?
  • Maytag Master
  • 842 Answers
Can I get more information as to the model number of this unit. I would like to research this and understand why the probe was the issue and why another one needs to be replaced. Do you get the same code when the probe is disconnected? I know there was issue with the probe at one time but I haven't seen this in a long time as most people rarely use it. Get back to me and I will see what I can locate for you. Thanks
Posted on Nov 22, 2014
Testimonial: "It's a Maytag Gemini MER6770AAW Electric Double oven. They said F1-1 Error code was the top ovens sensor probe. Which they replaced. After leaving I ended up getting the same F1-1 Error Code again on the top oven. They wanted to come back and replace the bottom sensor probe. Which at the time I did not understand since it was only the top oven that gave the Error Code. Then of course the following day I received the same error code after using the bottom oven. I am awaiting delivery of sensor probe which I can fix for 20 bucks rather than pay them another 200.00. The came back and said it is probably the touch pad which would be 400.00 plus labor to replace. So hope it is just the bottom sensor and I can fix it . Since Thanksgiving is right around the corner. Thank you for helping."
  • Gere knutson Nov 23, 2014
    Hi again, I reserached this issue and before I change that keypad I would inspect the harness thats for the probe from the clock to the connection at the sensor. At room temp it should read 1050 ohms at the clock connection. This will tell you the the harness is good. without checking can cost you a clock. I have seen wires cut or grounded out and cause this fault code to appear. The clock seeks information from the sensor every 6 seconds when the door is closed and if it fails to see or sense the probe (sensor). Inspect this connection before purchasing a clock. Good Luck
4 Suggested Answers
SOURCE: Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Posted on Jan 03, 2008
  • 1073 Answers
SOURCE: Main control panel
need to have a service company check the bottom oven elements first, the replacement part has only a 90 day warranty on it. if it is the control again ???????????????
Posted on Apr 10, 2008
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
replaced bottom element in oven , now neither element works ?
Posted on Jun 15, 2013
Repair man fixed top oven probe sensor due to a F1-1 error code. Top oven is still giving the same error code. Repairman wants to come back and charge 200.00 bucks again to replace bottom oven sensor.
The electronic control could have a bad touch pad that is causing this. You may need to replace the electronic control itelf. It is expensive almost 400.00 dollars.
Nov 20, 2014 | Maytag Gemini 30" Self-Cleaning...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Our oven keeps randomly beeping and flashing F10 on the display. marcnholly@yahoo.com
Sorry to read about your problem, I hope this helps you out.
F10
Runaway Temperature.
1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
I Have tried to help you.Please help me and rate/vote my response. Thanks and good luck.
If you live in the Denver Co area I can help.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore Ovens
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
Error codes how to reprogram oven electric oven the code F30 appears on led display
Hi
The F-30 error code states its a Open/shorted probe connection. Check resistance at room temperature & compare
to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor
wiring harness between EOC & Sensor Probe connector. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Also you can see the probe in the oven in the top left or right corner. It is pencil sized and about 5 inches long. You would need to get to the back of the oven to replace it. It has two 1/4 in screws that hold it in place. You then plug it into the control board and you are ready for baking again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Just purchased a Tappan TEF326FB and oven will not work. Get an error code F30 whenever press Broil or Bake buttons. top elements, clock, timer all work ok. followed manual instructions but can not get...
After much effort, and thanks to ABSOLUTELY NO HELP from Lowe's (where I bought this range) OR any of the contact numbers their 1-800-# referred me to (ie. SEARS Appliance repair in Californina, Chicago, etc.) or the the local Warranty repair service here (where we were finally referred to - they were "too" busy" to come look at it until 7 days later on June 25),
I managed to find out that the "F30" error code meant an "Open probe connection". and to "check resistance at room temp & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Chck Sensor wiring harness between EOC & Sensor Probe connection". I had no way to troubleshoot all of this or even to know where to look for the RTD probe or the wiring harness hookup. By the time I was able to find out what the error code mean't, I had taken the range back to Lowes where they tried to tell me that they shouldn't take it back because I had bought it a week earlier - even though It sat in the box and was not installed until 7 days after purchased. They finally took it back.
I promptly went to another appliance dealer (not Lowes or Sears) and bought a similar range which worked fine upon hookup. Too much hassle dealing with these folks.
Jun 19, 2009 | Kitchen Ranges
Kitchen Aid Stove goes into clean mode
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&Y
Apr 13, 2009 | KitchenAid KERC506HBS Electric Kitchen...
F-30 code
Hello mrteri1, CALL THE REPAIR MAN AND LOWES NOW!!! You need documentation of the first call AND of the NAME of who you spoke to for this second error. Now for wifes sake there is a good chance rebooting the EOC corrected the error for the time being. Correcting the problem requires a EOC replacement from what the DVM reading stated. I wish you a happy Thanksgiving & Merry Christmas.
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
My stove is a Ge Profile from 1998- when I turn on the oven F3 flashes- and shuts off-
Every fault code I have found for GE model ranges says this fault code is an oven sensor error. The oven sensor is a small probe that sticks out from the oven wall (usually along the back or side somewhere). This probe varies in resistance as the oven heats and sends a signal to the control board. If the probe is defective, or if you have a broken wire, you will get this fault code. The following link explains how to troubleshoot and/or replace an oven probe:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
I hope this is a simple fix for you. The repair is simple if you follow the instructions. If you require assistance locating any replacement parts, please post back with your complete model number. I hope this helps you.
Jul 24, 2008 | GE Kitchen Ranges
G.e electic profile slide in oven
All three codes, very odd, f3 f4 pertain to oven sensor short, or connection issue, f5 also asks to check resistance of sensor , so id try replacing oven sensor. sort probe located on top left or right side of oven cavity, 2 screws hold it place(sometimes youget lucky and will remove from front, if not you need to remove back panel and unplug and replug new sensor.cost for part can be $40-100, depending ion model
Feb 24, 2008 | Ovens
Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
70 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
