Question about JVC Av-56wp30 Iart Pro 56" Widescreen Hdtv-ready Rear-projection Tv
Cant aline green bulb using convergence menu
Used convergence menu on remote can't get green bulb to aline
  • JVC Master
  • 10,291 Answers
There are two or three convergence modules in the TV that have to be replaced. They solder to the circuit board. You can get these parts at shopjimmy's web site if you feel you can fix it yourself. Otherwise prepare to spend $400 plus parts to have a shop do it.
Posted on Nov 20, 2014
Will putting a new/ used projector assymbley in my 50in philips fix my convergence problems?
set uses two chips (most likely stk-392-120) and they will have to be replaced and set adjusted in tech menu---can tell you access is only with original remote (062597 status)
Mar 19, 2012 | Philips Televison & Video
I have a Toshiba CT-90121 and my convergence is off. I can adjust the blue and red in the menu but cannot aline them with the green crosshairs. Do I need a new green projector or something else?
You need to remove the convergence Board and repalace the convergence IC's and and replace electrolytic caps and check for resistors that have changed in value. You can getb the parts at www.mcmelectronics.com com or just purchase a new board at www.partstore.com .
Oct 07, 2011 | Toshiba 65HDX82 65" Rear Projection...
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
My t.v is having a convergence problem, and when using menu button from the remote control. there is no convergence option. Would adjusting the Lens from inside the t.v, give the same possible solution as...
Replace Both of your convergence ICs they are mounted on front bottom bord to left hand side will have STK on them STK392-150s Also CK pico fuses in front of ics they look like resistors but will be yellow or green pico fuses 5amps/6amps Call Mats for ICs 1-800-628-1118 And you Have to know How to Enter Service Menu for alinement to Convergence. PRESS( display/ ch /5 / vol- do this in order then you shold be in the service menu!
Jan 02, 2010 | Sony KP-43HT20 43" Rear Projection...
My zenith projection tv model R49W36 wont aline the colors green,red and blue
Its a convergence problem. You can get complete parts and instructiosn for this fix from www.TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Dec 22, 2009 | Zenith R49W36 49" Rear Projection HDTV
Picture is distorted w/ aline on top and bottom
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 30, 2009 | RCA HD65W140 65" Rear Projection...
Sony kp 51ws510 convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 19, 2008 | Sony KP-51WS510 51" Rear Projection...
Samsung 42" projection green and only green out of focus? Bulb? Tube? IC?
Just had new Ic?? Meaning single?? The symptoms you're describing are a convergence failure. That unit takes Stk392-040 Sanyo Ics and be aware there are a ton of Chineese knock-offs out there that can cause you real trouble, so purchase them from only a reputable part distributor... You need to change both amps, test all 3.9 ohm-2w resistors in that circuit, like Rz123 and Rz124 and check Fd102 3.5a pico fuse for open. That's actually a really easy set to work on for convergence problems because the entire convergence amp board is easily removed.
Bill
Dec 10, 2007 | Samsung HCM4216W 42" Rear Projection...
Convergence
Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
JVC Av-56wp30 Iart Pro 56" Widescreen Hdtv-ready Rear-projection Tv Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
