Question about Philips Televison & Video
I have a 47" Philips model 47PFL3603D/27 it began having problem of remote not controlling volume eventually had sizzling sounds came home turned it on and no picture but loud uncontrollable volume t
I have a 47" Philips model 47PFL3603D/27 it began having problem of remote not controlling volume eventually had sizzling sounds came home turned it on and no picture but loud uncontrollable volume took back off of tv saw burn marks on power board near a large square component with double copper wrapping mfg# 272217100571. Do you know if we replace this power board should it fix the issues I have described. Please HELP as I dont have the $ to buy another TV. Thanking you ahead of time
  • Philips Master
  • 10,263 Answers
Check shopjimmy's web page for replacement boards.
Posted on Nov 20, 2014
    Top Expert:
  • Philips Master
  • 75,289 Answers
Contact the authorized service centre for Philips. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
  • 138 Answers
SOURCE: Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Posted on Aug 20, 2008
ohms
  • 1879 Answers
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
Philips remote control not working
have the remote tested, any repair shop can do this and usually for free.
If remote is good the receiver in the set is likely bad.
Nov 27, 2012 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
How do i connect my pc to my tv
Yes it supports PC hook up. You can hook it in four ways using either an S-Video, HDMI or DVI connector.
  1. Connect the PC to your TV using either of the above connectors.
  2. Press MENU on the remote control and FEATURES > MODE SELECTION.
  3. Select PC and press OK to confirm your choice.
  4. If necessary, adjust picture settings.
  5. Set the picture format to Unscaled when using wide-screen PC resolutions.
  6. Press MENU to exit.
Oct 08, 2009 | Philips 47PFL3603D LCD TV
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
AUDIO
Philips TVs have an audio technology called automatic volume leveler (AVL). This was designed to eliminate the volume increase with commercials.
This setting is available in the audio page of the TV settings menu. turning the AVL option on should help with this problem.
Aug 19, 2008 | Philips 47PFL3603D LCD TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
