Question about Building Materials
Can't get into my garage one wire on the door has broken
    Master:
  • 966 Answers
Neil, which wire on the door, What type of garage door opener unit is it- brand, model etc. Can't the wire be replaced?Need more info.
Posted on Nov 20, 2014
How do I fix the close feature on my garage door opener?
Your electric eye sensors are not aligned, or not working or you have a loose wire or broken wire to them or a shorted wire on the sensors.
Apr 28, 2015 | Building Materials
Wireless garage door opener works wired one doesn,t
Either the wall control has gone bad or you have a broken wire going to it.
Nov 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
HBW0777 garage door opener. pulled debris from around one sensor light. Now neither sensor light is on.
You may have broken the wire going to the sensor. Some older models have wiring that unplugs at the sensor. This could be the case here and it is unplugged.
May 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage door control panel will not open the garage door when the button is pushed.
DO THE REMOTES WORK??
IF THEY DO IT WOULD LIKELY BE A BROKEN WIRE TO THE WALL CONTROL.
Jun 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman Garage door opener - doesn't activate, only the light blinks. Neither sensor has any lights lit. Any suggestions?
If you mean the main light blinks when you try to close the door then you have bad door sensors or the wiring going to them. Make sure the connections are tight and the wire is not broken somewhere.
Nov 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have problem, with my door garage. it desn't
IF THE DOOR OPENS WITH YOUR REMOTE BUT DOESN'T CLOSE (AND WORKS NORMALLY FROM THE WALL BUTTON) THE PROBLEM IS IN THE SAFETY EYES - CHECK TO SEE THAT BOTH LED'S ARE LIT.
IF NOT CHECK WIRING POLARITY - CHECK FOR BROKEN WIRES - CHECK FOR ALIGNMENT AGAIN.
Sep 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlian garge door opener only closes by holding down wall push button,no lights at safty sensors
Probably a broken wire to one of the sensors. Holding down the wall button overrides the sensors.
If you move the wires at the back of the power unit and at the sensors watch for the sensor lights to flicker. - If they do the wires you just moved are the problem.
If moving the wires doesn't help you will need to trace the wires & watch for a broken wire loose connection etc.
Hope this helps
Jul 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
37 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
