Question about Dryers
I have a may tag dryer dg 412 my flame was going off to soon about 9 seconds I have replaced the igniter the gas valve coils and the heart sensor on the flame/blower housing but I did not unplug befor
I have a may tag dryer dg 412 my flame was going off to soon about 9 seconds I have replaced the igniter the gas valve coils and the heart sensor on the flame/blower housing but I did not unplug before doing this and shorted one of the heat sensor wires to the flame housing and now the igniter does not glow red any ideas
    New Friend:
    Problem Solver:
  • 5 Answers
For starters you should always unplug any electrical device before you start working on it. You probably fried the sensor that the wire was going to. Once you replace the sensor it will probably work just fine.
Posted on Nov 20, 2014
jsrock516
  • 5911 Answers
SOURCE: no heat
You may have a weak igniter. Just because the igniter glows, does not mean it is working properly. The glow bar type igniters are supposed to draw a certain amount of current in order for the gas valve to open. If the current potential is never met, the gas valve will not open. This is a safety feature used to prevent gas flow without ignition. The current readings for the igniters are as follows: Round style glow bar: 2.7 to 3.2 amps Square style glow bar: 3.2 to 3.7 amps If it is reading less than the required amperage, replace it. This may just solve your problem. Let me know if this helps you.
Posted on Sep 08, 2007
the dr
  • 447 Answers
SOURCE: kenmore gas dryer 80series model 110.c72852101
90% of all gas dryers lighting intermittently is resolved with new coil packs on the gas valve. The coils are replacable fairly easily and inexpensive.
Posted on Oct 04, 2007
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
dragonsthatk
  • 547 Answers
SOURCE: flame goes out after 5 seconds
the thermocupple is a small tube that when heated shrinks to let gas flow if it is no good gas will not flow change the thermocupple thank you for useing fixya please rate me
Posted on Feb 24, 2009
SOURCE: glow ignitor works, but no flame ignites. ohmed out gas valve coil with wires disconnected = OL is it my coil?
You have a bad flame sensor. Replace it.
Posted on Sep 18, 2009
Ignitor is lighting but silinoid is not opening to let gas through.Roper model # RGS7646KQ3
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
I hope i have been able to help you fix your dryer,
GENE
Sep 17, 2011 | Dryers
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
Dryer starts, but does not heat up. Igniter ignites, but no heat. Gas to rest of house is operable.
Thier are 2 possible things causing it not to heat.
1) The flame sensor is bad..if the igniter glows BUT does not go off it will be the FLAME SERSOR that is the problem
2) the coils that open the gas valve are defective..If the igniter DOES go off but no flame it will be the gas valve coils
while i dont know what brand you have their are fairly unuvesal parts for the coils or flame sensor
Part#'s
GAS VALVE COILS 279834
FLAME SENSOR THAT FITS ON RIGHT OF BURNER TUBE WE4X448
FLAME SENSOR THAT FITS ON LEFT OF BURNER TUBE 338906
GENE
Aug 28, 2011 | Dryers
Maytag LDG7500AAL dryer ignitor lites up but burner will not lite
Their are 2 possibilities,based on exactly what is happeninh with your dryer.
1) If after the igniter came on,it stay on for 30 seconds to 1 minute and went off,but there was no flame as soon as the igniter went off? IF that is what your seening the coilds that open the gas valve are the problem. They are the 2 pod things on the top of the gas valve one of them has a plug with 2 wires on it,the other has a plug with 3 wires.IF no flame after the igniter went out those coils need to be replaced.
2) If the igniter came on and STAYED on and never went off within 1 minute?
for that since the igniter never turns off. The problem will be the flame switch. Its the black rectangle box mounted to the outside of the burner cone and has 2 wires attached to it.If the igniter did NOT go off the flame switch will be needed
The part numbers are,
FLAME SENSOR 338906
The parts could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
midwestapplianceparts.com
GENE
Aug 18, 2011 | Maytag Dryers
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Maytag DG 412 won't stay lit
If the dryer can be restarted within 1 minute and it starts again it's not likely the coils. It may be poor air flow causing the safety thermostat on the flame tunnel going off as a warning. If it takes several minutes off to make it start again, it's likely the coils. When they cool down the broken coil contracts and the broken ends come back together (you can't see this). The coil kit number is 12001348 for the DG412.
Be careful not to break the ignitor when you service these...it is VERY prone to breakage. Turn off gas and electricity before servicing.
Aug 23, 2009 | Dryers
Dryer starts but flame extinguishes after a few seconds
it is clear from your reading symptoms that is asensor thermostat problem
thanks
Jul 11, 2009 | Dryers
Not hearting up
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
May 30, 2009 | Maytag MDG9606 Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
