Question about Marantz SR-5600 Receiver
Humming/Buzzing noise in my Marantz SR5600-even on lowest volume-
I tried swapping the speaker wires-no luck
    Top Expert:
  • Marantz Master
  • 74,383 Answers
Check the main filter capacitor at its power supply section circuit. Electro help
Posted on Nov 20, 2014
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
Posted on Feb 23, 2012
Humming/buzzing
This is a nice speaker. You could get humming from the wires being crossed they actually do have polarity and better speakers will hum if the wires are crossed. The volume cloud also be too high without input. You also may have some interference with other audio wires or power wires close to the speaker.
Apr 05, 2014 | ElectroVoice . Speaker
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
One of my Q 75's is just not performing properly,all the drivers make sound,just not enough of it,I've swapped both speakers from right to left so it's not wiring or the reciever.No buzzing or...
Try reversing the POLARITY of the wires on the speaker that is playing at a low volume (swap wires connected to the + and - terminals of the speakers). This would put the speaker back in phase if it were reverse connected, and provide the expected volume level again.
May 23, 2011 | KEF Audio Q75 Speaker
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
Problems connecting turntable to amplifier
I hope you have it connected to the Phono input on the left rear of the receiver. Otherwise the minute signal generated by the phono cartridge is too small for the other inputs to process.
The buzzing noise/bad channel is probably a bad connection in the tonearm/headshell connection or one of the 4 wires attaching the cartridge to the shell. If you DON'T want to blow up your speakers, TURN YOUR RECEIVER OFF, turn the volume to 0 or select another input before messing around with the tonearm.
Swap the two channels from the tonearm to the Phono connectors to prove the buzzing is external (at the turntable). I think the Dual CS415 uses the old standard headshell. With the volume down flip the lever toward the back, carefully remove the assembly and look over the tiny multi-colored wires with the brass crimp-on ends. We're looking for tight kinks or broken wires. Then put it back. maybe reseat it a few times to wear off any oxidation and try it again.
Apr 01, 2009 | Audio Players & Recorders
Marantz SR5600 Problem
HI...
From others I've worked on it appears that some solder joints on the volume control assby have "let go".
There are a few places that stock Marantz parts online.
Typically ,this isnt a consumer serviceable issue.
I can possibly suggest a repair place depending on where you are.
Hope that helps.
Jan 03, 2009 | Audio Players & Recorders
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
Marantz SR-5600 Receiver Logo
198 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
