Question about Spectra Chevrolet Blazer 94 93 92 Tahoe 97 96 95 Gmc Yukon Car Parts Auto 1994 1993 1992
Yukon floods on first start after sitting over night
    New Friend:
  • 3 Answers
Check your throttle positioning sensor, it may be sticking when the engine cools down, and may be flooding your vehicle. It should come up on a diagnostic tester, in the codes.
Posted on Nov 19, 2014
Testimonial: "thanks but i replaced it and also the coolant temp sensor but no change accept for now that it is cold out it has been starting ok. their has not been any code of any kind yet"
  • Pam Kubesh Nov 19, 2014
    I experienced same problem. It may be in the brain box of the vehicle.
Car wont start when parked on hill
I HAVE THIS EXACT PROBLEM. If you got this repaired, what was the fix??
Nov 26, 2012 | 2003 GMC Yukon XL
2000 Yukon denali having trouble starting. Sounds flooded. After it sits awhile it will start. Replaced fuel pump. Still having problem. Security light is on. Replaced ignition switch. Please advise.
If it is flooding,fuel is not the problem.Sorry you did a pump already.You need to check spark and air,I would start with spark.Check your plugs for spark.If they all spark normal,that also means the ignition coil is good.That leaves air.Check the filter and intake hose for leaks,holes,etc.I would guess spark,but you never know what you'll find.If you are not 100% sure how to check spark,sounds like you probably do though,just comment on this post and I get an auto email linked to here and tell you the best method.Good luck! Greg
Aug 19, 2010 | 2002 GMC Yukon Denali
03 yukon driver side mirror, rearview going day to night any time
you either have a loose connection to or a failing daylight sensor, get it replaced
Feb 25, 2010 | 2003 GMC Yukon XL
When car sits over night cold floods & will not start
It's fuel injected! Tell me where you come up with flooding? It won't start on a cold day,other wise okey and runs well,I doubt it?
Feb 11, 2010 | 1989 Oldsmobile Eighty Eight Royale
2000 Yukon Hard to start, rough accelleration
First things first. The morter is direct injection, no throttle body. The injectors inject fuel directly into the cylinder. A few possible simple causes. Bad gas is and can always be a contender (my mom had the exact same issue with it stalling). Try putting some water remover in the tank and going to a station that has lots of traffic (gas doesn't sit as long and is less likely to have water in it). Also you can use Lucus fuel treatment in each fill up to help prevent fuel breaking down. The injectors could possibly be going bad (hard start, hesitation are also signs of injectors) but could also be a failing fuel pump or fuel filter may be geting plugged. Also the CPS crank position snesor which would also contribute to this issue. I would start by taking it to the local parts store for code scanning to see if it points you anywhere specific first and if not then start with the cheapest things first or have a no start diagnostics performed at a service shop..
Sep 22, 2009 | 2001 GMC Yukon XL
2002 Yukon XL 6L won't start or starts rough on
Have the fuel pressure switch checked.
Sep 08, 2009 | 2002 GMC Yukon XL
Starting problem after engines warm smell gas
I had the same problem. It may start to or already is stalling as you slow down or stop. I changed my fuel pressure switch located right on the fuel rail on top of the motor. It's about $80.
Nov 17, 2008 | 1999 Chevrolet Silverado 1500
Nissan Sentra Series 3 won't start
I have the same problem. When I let the car sit over night it cranks right up, but if I cut it off it is off for hours and won't crank.
Jun 14, 2008 | 1995 Nissan Sentra
Spectra Chevrolet Blazer 94 93 92 Tahoe 97 96 95 Gmc Yukon Car Parts Auto 1994 1993 1992 Logo
Top Spectra Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
Roy McCracken
Are you a Spectra Car Audio and Video Expert? Answer questions, earn points and help others
