Question about 2001 Ford Taurus - Wagon - Weathershield HP Car Cover
Fuel pump inertia reset - 2001 Ford Taurus - Wagon - Weathershield HP Car Cover
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
It is either under the dash in the right side kick panel or in the back inside of one of the side panels. I think it is in the back on those cars.
Posted on Nov 19, 2014
What does the fuel reset indicator on the panel stands for? Ford explorer 98
Fuel Reset
The FUEL RESET indicator is grounded through the inertia switch whenever the vehicle is subjected to a high force situation. The inertia fuel shutoff switch (IFS switch) (9341) cuts off the fuel pump motor. The FUEL RESET indicator illuminates when the IFS switch has been tripped
Mar 31, 2015 | 1998 Ford Explorer
1999 lincon town car no power to fuel injector
Sometimes a crankshaft sensor does not send the signal to fire either the spark or the fuel injectors. If the fuel pump relay is not getting power, the inertia sensor will not have power either. The inertia reset is just magnetic and does not depend on having power to reset.
You can check for current at the Inertia sensor and at the fuel pump relay. You can also have fuel pressure at the test port without the injectors working, which is the easiest test of all,
You need the sequential firing pulse for the injectors. Have you checked the EEC Relay?
Apr 20, 2014 | 1999 Lincoln Town Car
1989 f-250 inertia fuel shut-off switch switch location
This should be in the owner's manual. I found the below on autozone.com, their repair help location:
An inertia switch is used as a safety device in the fuel system. The inertia switch is located in the cab, generally under the dashboard on the right side. It is designed to open the fuel pump power circuit in the event of a collision. The switch is reset by pushing each of 2 buttons on the switch simultaneously (some models use switches with only one reset button). The inertia switch should not be reset until the fuel system has been inspected for damage or leaks.
When the ignition switch is ON , it turns the EEC power relay ON . The EEC power relay provides power to the powertrain control module (PCM) and the control side of the fuel pump relay. Power for the fuel pump(s) is supplied through a fuse link or high current fuse attached to the starter solenoid (battery side). From the fuse link or high current fuse, current flows through the fuel pump relay and inertia switch to the fuel pump(s). The fuel pump relay is controlled by the PCM.
When the ignition switch is turned ON , the fuel pump(s) will operate. If the ignition switch is not turned to the START position the PCM will shut the fuel pump(s) OFF after 1 second. The PCM will operate the fuel pump(s) operate the fuel pump(s) when the ignition switch is turn to START position to provide fuel while cranking.
After the engine starts, the PCM will continue to operate the fuel pump(s) unless the engine stops, drops below 120 rpm or the inertia switch is tripped.
Dec 28, 2013 | 1989 Ford F 250
Fuel Reset
Only Ford products use an inertia switch for the fuel pump.
You have an ASD relay that could be failing, but no switch.
May 10, 2013 | 1995 Dodge Neon
How do i reset my 1999 mustang fuel pump?
Reset your fuel pump? If you mean the inertia switch, all you have to do is push the button on the inertia switch to reset it. It is located in the lower left rear corner of the trunk.
Please note that if your fuel pump is not working, it is NOT the inertia switch unless you have been involved in an accident, or slammed something (like a curb or a HUGE pothole) pretty hard recently. If this is what happened, the engine would have died IMMEDIATELY after such an accident.
Apr 30, 2012 | 1999 Ford Mustang Cobra
Car will turn over but won't start. Through the
No noise from fuel pump when you turn over the car .First thing get voltage at fuel pump relay checked, is there 12 volt to the relay.If no, then problem is again the relay.--------- To reconfirm the problem, try other test, that is remove the relay and by pass the relay terminals with a jumper wire .Then with 12 volt external battery give power to fuel pump connector and see, if the fuel pump starts, then its clear that fuel pump relay is faulty.----------- Also other problem can be fuel pump inertia switch.If the inertia switch is faulty then also fuel pump will not start.-------- The fuel pump relay on a 1995 Ford Explorer is in the power distribution
box, in the engine compartment, driver's side near the firewall.----------
The fuel pump inertia switch is in the right front passenger area
it is below the dash but above the carpet in the right hand corner.--------
Its a push button type inertia switch.
Fuel Pump Activation
When ignition switch is turned to START position, PCM operates fuel pump relay to provide fuel for starting engine. PCM senses engine speed and shuts off fuel pump by opening ground circuit to fuel pump relay when engine stops or engine speed drops to less than 120 RPM. When ignition switch is in ON position, EEC power relay is energized (contacts closed). Power is provided to fuel pump relay and timer in PCM. Fuel pump receives power through fuel pump relay contacts.
Inertia Fuel Shutoff (IFS) Switch
All models use an electrical interrupt switch in fuel system. During a collision or vehicle rollover, electrical contacts within inertia switch open, shutting off fuel supply to electric fuel pump. Fuel supply is interrupted even when engine is running.
A reset button is located on switch assembly. If electrical circuit trips, vehicle will not restart until switch is reset. Fuel system should be inspected before resetting switch.
IFS switch is located under instrument panel, near right side of transmission hump.
----------- If the fuel pump relay, the inertia switch and fuel pump all checked ok, and fuel pump is working with direct 12 volt source to fuel pump.Then problem relates to computer.The computer (power control module, PCM) is faulty and has to be replaced.--------- This will help.Thanks.Helpmech.
Jul 17, 2011 | 1995 Ford Explorer
Ford explorer 93 where is the fuel shut off switch
For details regarding fuel pump and fuel pump switch click the link below:--- http://technoanswers.blogspot.com/2011/06/where-is-fuel-shut-off-switch-on-1993.html This switch is also called inertia switch For fuel pump reset switch location and diagram click this link below:--- http://technoanswers.blogspot.com/2011/06/fuel-pump-reset-switch-location.html ---------- This should help.Thanks.Helpmech.
Jun 04, 2011 | Ford Explorer Cars & Trucks
Turned of car, will not start it turns over, but doesn't seem to be getting any fuel
Try A SMALL SHOT Of Starting Fluid Sprayed into the Snorkel
Intake @ Air filter. If it Starts and Does NOT Run After Burning Starting Fluid the Fuel Pump Has Failed. (My Personal Hunch) is (FUEL PUMP FAILURE) BE SURE TO ELIMINATE THE INERCIA SWITCH< it is a fuel shut off switch >>>>> WARNING: Do not reset the inertia switch button if you see or smell fuel.
  1. Turn ignition switch to OFF.
  2. Check for leaking fuel in the engine compartment, fuel lines and fuel tank.
  3. If no fuel is apparent, reset the inertia fuel shutoff switch by pushing the reset button on top of switch.
  4. Turn ignition switch to START for a few seconds, then to OFF.
  5. Again, check for leaking fuel.
LOCATION
  1. Open luggage compartment door.
  2. Remove two screws retaining inertia fuel shutoff switch.
  3. Disconnect wiring harness connector from inertia fuel shutoff switch and remove inertia fuel shutoff switch.
  4. To install, reverse removal procedure.
Aug 17, 2010 | 1996 Mercury Cougar XR7
I cant find the inertia switch to reset my fuel pump
No Inertia switch on Saturns! Check Fuel Pump Fuse Or Fuel Pump!
May 09, 2009 | Saturn Ion Cars & Trucks
2001 Ford Taurus - Wagon - Weathershield HP Car Cover Logo
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
 Ronnie
Ronnie
Level 1 Expert
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
